Mapserver 5 cgi Compilation problem
Tamas Szekeres
szekerest at GMAIL.COM
Thu Feb 7 04:21:11 EST 2008
Stefano,
Would you provide the core dump and/or any further info you have so as
to locate the problem?
Best regards,
Tamas
2008/2/7, Stefano Bonnin <stefano.bonnin at comai.to>:
> Hi, I've just compiled the 5.0.0 version of mapserver in my freebsd 5.3.
> The compilation step seems ok and I don't receive any errors.
> But when I try:
> ./mapserv -v
> MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> mapserv in free(): error: chunk is already free
> Abort (core dumped)
> same problem with 5.0.2 version.
> I compile with the following configuration:
> ./configure --with-proj=../proj-4.6.0/ --with-php=../php-5.2.5
> --with-postgis=/usr/local/postgresql/8.3/bin/pg_config
> --with-freetype=/usr/local/include/freetype2/freetype
> --with-gd=/usr/local --without-tiff --with-gdal=/usr/local/bin/gdal-config
> --with-ogr=/usr/local/bin/gdal-config --with-httpd=/usr/www2/bin/httpd
> --with-wmsclient --with-wfsclient --with-wfs
> --with-curl-config=/usr/local/bin/curl-config --with-libiconv=/usr/local
> but a simple ./configure give the same problem
> Thanks in advance
> Stefano
