[mapserver-users] Query in frame with mapserv-demo doesn't work
Begoña Gonzalez
begodom at gmail.com
Wed Feb 13 14:59:54 EST 2008
I already have my layers definition with template...
from Oscar ^_^ <oscarfbh at gmail.com> hide details 7:57 pm (58 minutes ago)
to Begoña Gonzalez <begodom at gmail.com>
date Feb 13, 2008 7:57 PM
subject Re: [mapserver-users] Query in frame with mapserv-demo doesn't work
mailed-by gmail.com
Hello Begoña, to do a query in a layer You must put it queryable.
Configure a TEMPLATE in your layer definition to make your layer queryable.
2008/2/13, Begoña Gonzalez <begodom at gmail.com>:
> - Hide quoted text -
> Hello All
> I´m new with MapServer.I´m trying to build my aplication based in mapserv-demo.
> All the examples of mapserv-demo works fine. I´ve made a copy of all the files and rename the aplication.
> I want to have the same results as Adds dhtml rubber-band box.
> I´ve adapted the index.html, the itasca_adds_dhtml.html(renamed plantilla.html) and itasca.map (renamed eielmap.)
> In itasca_adds_dhtml.html and itasca.map I just changed regarding the layers and the map coordinates and size.
> The index.html file I have adapted in this way, to have my starup file and not having to choose the template in the select:
> <form method=GET action="frames_dhtml.html">
> <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
> <input type="hidden" name="template" value="plantilla.html">
> <input type="hidden" name="zoomsize" value=2>
> <input type="hidden" name="map" value="/ms4w/apps/eiel2/eielmap.map">
> <input type="hidden" name="root" value="/eiel2/">
> <input type="hidden" name="map_web" value="IMAGEPATH '/ms4w/tmp/ms_tmp/' IMAGEURL '/ms_tmp/' TEMPLATE '/ms4w/apps/eiel2/plantilla.html'">
> </form>
> All works fine, the zoom bottons, the layers... except the query.
> When I do a query,into the bottom frame not show me anything, there is no error message of mapserver. The browser shows a message error:
> "no se puede encontrar la pagina web" "the web page is not found...", the url command is that this seems to be well:
> http://localhost/cgi-bin/mapserv.exe?mode=query&map=/ms4w/apps/eiel2/eielmap.map&imgext=642050+4192100+646950+4197000&imgxy=317+187&imgbox=317+187+317+187&imgsize=400+400&layers=ABASTECIMIENTO_A+MANZANAS
> Thanks in advance and sorry form my english.
> Begoña
