[mapserver-users] Ka-map on leopard
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Feb 13 16:15:27 EST 2008
Hi, I'm trying to ues Ka-map on mapserver in a mac osx 10.5.2 environment.
My mapserver is up and running (i can use wms service). I've put ka-map in
my /users/simo/sites dir, my mapfile is:
MAP
NAME maptry
STATUS ON
EXTENT -180 -90 180 90
SIZE 600 600
UNITS dd
IMAGECOLOR 255 255 255
IMAGETYPE png
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/tmp/kacache/"
IMAGEURL "/tmp/kacache/"
END
LAYER
NAME road
GROUP roads
TYPE LINE
DATA ../data/roads.shp
STATUS ON
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "roads"
END
END
END
and my config.php is:
$aszGMap = array (
'title' => 'prova',
'path' => '/users/simo/sites/mapfile/kamap.map',
'scales' => array( 40000000, 25000000, 12000000, 7500000, 3000000,
1000000 ),
'format' =>'PNG'
/* Sample authorized_users entry. See auth.php for more details:
* ,'authorized_users' => array('popplace' => array('user1',
'user2'),
* 'park' => array('user1')
$aszMapFiles = array( 'prova' => $aszGMap
/* Add more elements to this array to offer multiple mapfiles */
When I access to ka-map i can see the standard interface but no mapfile are
loaded. I'm sure that the path is correct.
I think the problem is in the php_gd, because in my mac I haven't found any
php_gd.so files.
I've installed all frameworks from http://www.kyngchaos.com/ GD framework
included. I've also installed the php-cgi 5.2 and used phpenable.app.
But in my phpinfo, in the configure section, i read :
'--with-gd=/Users/Shared/unix/gd' but in this folder I haven't any unix dir.
All files are in /library/frameworks/gd.framework.
Can you help me?
Thanks in advance.
Simone Dalmasso
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080213/6140647d/attachment.html
