[mapserver-users] RE: [UMN_MAPSERVER-USERS] Strange Projection
Issue in MapServer
Fawcett, David
David.Fawcett at state.mn.us
Fri Feb 15 11:31:22 EST 2008
This looks like a projection issue.
If you run ogrinfo on the tile index what do you get?
How about if you run gdalinfo on one of the image tiles?
-----Original Message-----
Sent: Friday, February 15, 2008 10:23 AM
To: Fawcett, David
Subject: Re: [UMN_MAPSERVER-USERS] Strange Projection Issue in
Sure thing, thanks David.
I am using MapServer for Windows version 2.2.6, I have attached
both again for you.
Thanks,
Rob
On Fri, Feb 15, 2008 at 10:47 AM, Fawcett, David
<David.Fawcett at state.mn.us> wrote:
Robert,
Can you post the text of your map file and the version
of MapServer that
you are using?
I also didn't see the .png attachment come through.
David.
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Robert Hyx
Sent: Friday, February 15, 2008 9:30 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Strange Projection Issue
in MapServer
Hello Everyone,
I am having a strange problem with mapserver and
reprojecting on the
fly. I have some imagery in mapserver that has been
processed but is
still kept in its native projection 26915, and when I
use the
PROJECTION
"init=epsg:4326"
END
in the header (above the paths of the shape files)
and I use
PROJECTION
"init=epsg:26915"
END
in each layer (above the path of each shape file), I get
another version
of the imagery over on the other side of the world in
addition to the
normal version of the imagery that appears in the
correct place.
I have attached a png of what the imagery that appears
in the incorrect
place looks like. Any help would be greatly appreciated.
Thanks,
Robert
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080215/23017291/attachment.html
