[MAPSERVER-USERS] loadWeb() error on Windows 2003 (MS4W package)
riteshambastha
ritesh.linux at gmail.com
Sat Feb 16 01:31:19 EST 2008
Well Suresh,
I just saw an error in your code.
Check this in your html code:
[img]
Here, [img] catches the name of generated image file. This image file
resides in tmp directory. So, you will have to give it a path. Something
like /tmp/[img]. Play around this.. you will get your answer.
Regards,
Ritesh
Suresh Nimbalkar wrote:
> Hi!
> I have just started my exploration in Mapserver on Windows platform with
> MS4W package. I am using Bil Kropla's Mapserver book. When I worked out
> the first example (of chapter 2), a simple example using mapserver in
> CGI-BIN mode, I get the following error
> loadWeb(): Unknown identifier. Parsing error near (c):(line 1)
> I tried changing the path information (TEMPLATE, IMAGE PATH), other
> parameters to ensure the simple 'Hello World' example map gets displayed,
> but I could not go further.
> I am producing the source code below of the two files.
> File: hello.map
> # This is our "Hello World" mapfile
> NAME "Hello World"
> SIZE 400 300
> IMAGECOLOR 249 245 186
> IMAGETYPE png
> EXTENT -1.0 -1.0 1.0 1.0
> WEB
> TEMPLATE "c:/ms4w/apache/htdocs/hello.html"
> IMAGEPATH "c:/ms4w/apache/htdocs/tmp/"
> IMAGEURL "/tmp/"
> END
> LAYER
> STATUS default
> TYPE point
> FEATURE
> POINTS 0.00 0.00 END
> TEXT "Hello World"
> END # end feature
> CLASS
> STYLE
> COLOR 255 0 0
> END
> LABEL
> TYPE bitmap
> END
> END
> END
> END
> File: Hello.html
> <html>
> <head> <title>MapServer Hello World</title></head>
> <body>
> <form method=POST action="../cgi-bin/mapserv.exe">
> <input type="submit" value="Click Me">
> <input type="hidden" name="map"
> value="c:/ms4w/apache/htdocs/hello.map">
> <input type="hidden" name="map_web_imagepath"
> value="c:/ms4w/apache/htdocs/tmp/">
> </form>
> [img]
> </body>
> </html>
> Would appreciate any help on this.
> Thanks in advance.
> Suresh
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it
> now.
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/loadWeb%28%29-error-on-Windows-2003-%28MS4W-package%29-tp15506112p15515012.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
