[mapserver-users] itemnquerymap output
Maxim Dubinin
sim at gis-lab.info
Mon Feb 18 11:35:10 EST 2008
Here is a portion of my map file. As you can see, I'm trying to use
the same template.html to return result of the query back into it. It
works under WEB when it stats, but seems like ignored
under LAYER that is being queried (qlayer=states_poly,qitem=State).
Well not exactly ignored, if I don't put anything in there it gives
an error message.
MAP
IMAGETYPE PNG
EXTENT -97.238976 41.619778 -82.122902 49.385620
SIZE 400 300
SHAPEPATH "defquery/"
IMAGECOLOR 255 255 255
WEB
TEMPLATE "template.html"
IMAGEPATH "/tmp/"
IMAGEURL "/tmp/"
END
QUERYMAP
STATUS ON
SIZE 400 300
STYLE SELECTED
END
LAYER # States polygon layer begins here
NAME states_poly
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "CLASS"
METADATA
qstring_validation_pattern '.'
END
CLASS
NAME 'States'
Maxim
Вы писали 18 февраля 2008 г., 8:06:58:
RG> On Feb 17, 2008 9:53 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
>> Thanks for suggestion, it was actually set. The strange thing is,
>> Mapserver doesn't care about what I put in there, as long as
>> LAYER\TEMPLATE "anything" exists. It could be any text as long
>> as its under LAYER\TEMPLATE, even if the file doesn't exist.
>> If I don't provide it, it gives me "msQueryByAttributes(): Query error. Requested
>> layer has no templates defined so is not queryable." error.
>> Is this template really for attributive results?
RG> The template is for either attribute or spatial (map) display. What
RG> gets displayed depends on the template. Maybe mapserver is not finding
RG> your template file?
RG> Rich
