[mapserver-users] itemnquerymap output
Richard Greenwood
richard.greenwood at gmail.com
Mon Feb 18 12:53:24 EST 2008
That all looks good to me. is template.html in the same directory as
your map file?
Rich
On Feb 18, 2008 9:35 AM, Maxim Dubinin <sim at gis-lab.info> wrote:
> Here is a portion of my map file. As you can see, I'm trying to use
> the same template.html to return result of the query back into it. It
> works under WEB when it stats, but seems like ignored
> under LAYER that is being queried (qlayer=states_poly,qitem=State).
> Well not exactly ignored, if I don't put anything in there it gives
> an error message.
> MAP
> IMAGETYPE PNG
> EXTENT -97.238976 41.619778 -82.122902 49.385620
> SIZE 400 300
> SHAPEPATH "defquery/"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE "template.html"
> IMAGEPATH "/tmp/"
> IMAGEURL "/tmp/"
> END
> QUERYMAP
> STATUS ON
> SIZE 400 300
> STYLE SELECTED
> END
> LAYER # States polygon layer begins here
> NAME states_poly
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> CLASSITEM "CLASS"
> METADATA
> qstring_validation_pattern '.'
> END
> CLASS
> NAME 'States'
> Maxim
> Вы писали 18 февраля 2008 г., 8:06:58:
> RG> On Feb 17, 2008 9:53 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
> >> Thanks for suggestion, it was actually set. The strange thing is,
> >> Mapserver doesn't care about what I put in there, as long as
> >> LAYER\TEMPLATE "anything" exists. It could be any text as long
> >> as its under LAYER\TEMPLATE, even if the file doesn't exist.
> >> If I don't provide it, it gives me "msQueryByAttributes(): Query error. Requested
> >> layer has no templates defined so is not queryable." error.
> >> Is this template really for attributive results?
> RG> The template is for either attribute or spatial (map) display. What
> RG> gets displayed depends on the template. Maybe mapserver is not finding
> RG> your template file?
> RG> Rich
Richard Greenwood
www.greenwoodmap.com
