[mapserver-users] map mouseclick snafu
Paul Spencer
pspencer at dmsolutions.ca
Mon Feb 18 15:00:35 EST 2008
In the code that handles the mouse click on the menu, you need to stop
the event from propagating [1]. If you are using a javascript
framework such as prototype [2], it will probably have such a
mechanism (in prototype, for instance, you call Event.stop(evt)). If
you are not using a framework, you will need to add the code for
stopping the event, this is what prototype uses:
if (evt.preventDefault) {
evt.preventDefault();
evt.stopPropagation();
} else {
evt.returnValue = false;
evt.cancelBubble = true;
The quirksmode site has some good information general information
about javascript events [3].
Cheers
Paul
[1] http://www.quirksmode.org/js/events_order.html
[2] http://www.prototypejs.org/
[3] http://www.quirksmode.org/js/introevents.html
On 18-Feb-08, at 2:31 PM, Ben Thompson wrote:
> we have some dropdown menus above the map area. each item consisting
> of an <a href=xxx>
> problem is, the menus overlay the map when unrolled and for some
> reason the map gets the mouseclick too, causing it to repeat
> applying whatever tool was last used (zoom in, etc). How to tell the
> map not to do this (i.e., disable active tool), or, better, how to
> make it not get clicked in the first place?
> thanx,
> Ben Thompson
> mapserver-users at lists.osgeo.org
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
