re[MAPSERVER-USERS] ad angle from database to rotate symbol ->
Symbol definition error
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Feb 19 10:17:16 EST 2008
Paul,
I think the syntax for attribute binding is something like
ANGLE [orientation] (attribute value in brackets). Could you try
changing you map file and give it a try.
Best Regards,
Paul L wrote:
> Dear List
> I'm not the first one to ask this question, but I am unable to use the older
> list-posts as in the meantime (mapserver 5.0) the ANGLEITEM seems to be
> deprecated, if I understand this document
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
> correctly.
> I am reading points from a postgis-table and would like Mapserver to rotate
> the symbols of each point according to the rotation-value stored as integer
> in the same table. It works fine as long as I hardcode the angle like
> "ANGLE=45". As soon as I try setting ANGLE="orientation" I get the
> errormessage:
> getSymbol(): Symbol definition error. Parsing error near
> (orientierung):(line 126)
> Can you help me find my errors?
> Thank you very much
> Paul
> P.S. I can actually read the angle and display it as a label, so it
> shouldn't be a problem of reading from the database.
> LAYER
> NAME points
> TYPE POINT
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=test_postgis user=postgres password=postgres
> host=localhost port=5432"
> DATA "geometry from (select id, name, orientation, geometry from points)
> as foo USING UNIQUE id USING SRID=-1"
> STATUS DEFAULT
> TRANSPARENCY 65
> CLASS
> STYLE
> SYMBOL "U"
> SIZE 15
> COLOR 0 0 150
> ANTIALIAS TRUE
> ANGLE 45
> #ANGLE "orientation" #throws error: getSymbol(): Symbol definition error
> END
> END
> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
