[mapserver-users] AGG_Q + raster problem
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 19 10:46:01 EST 2008
Hans,
That is stange. I've tested mapserver 5.0.0. Beta 4 (it's
the only v5 I've got compiled) and it gives me a 24 bit
color image. What version of Mapserver are you using? Can
you send your entire map file?
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: <bfraser at geoanalytic.com>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, February 19, 2008 2:21 AM
Subject: RE: [mapserver-users] AGG_Q + raster problem
Yes, I'm still getting a quantized image using this
statement:
OUTPUTFORMAT
NAME 'AGG_PNG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
-----Mensaje original-----
De: Brent Fraser [mailto:bfraser at geoanalytic.com]
Enviado el: lunes, 18 de febrero de 2008 21:37
Para: Hans Castorp
CC: mapserver-users at lists.osgeo.org
Asunto: RE: [mapserver-users] AGG_Q + raster problem
So when you remove all the quantize options, you still get a
quantized
image on output? Using something like:
OUTPUTFORMAT
NAME 'AGG_PNG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
> This, by example
> De: Guillaume Sueur
[mailto:guillaume.sueur at neogeo-online.net]
> Enviado el: lunes, 18 de febrero de 2008 19:04
> Para: Hans Castorp; mapserver-users at lists.osgeo.org
> Asunto: Re: [mapserver-users] AGG_Q + raster problem
> what's the result in standard AGG mode ?
> Hans Castorp a écrit :
>> The result is the same with or without this line...
>> De: Guillaume Sueur
>> Enviado el: lunes, 18 de febrero de 2008 18:59
>> Para: Hans Castorp
>> quantize_colors=255 is maybe the reason why your colors
are reindexed on
>> a 256 colors palette.
>>> Thanks Brent, but there is a mistake, the example I
attached is not the
>>> mapservers original output: I have prepared it and give
.gif extensión.
>>> This is the way I configure my output:
>>> OUTPUTFORMAT
>>> NAME 'AGG_Q'
>>> DRIVER AGG/PNG
>>> IMAGEMODE RGBA
>>> FORMATOPTION "TRANSPARENT=ON"
>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>> FORMATOPTION "QUANTIZE_COLORS=255"
>>> END
>>> Thanks in advance.
>>> Enviado el: lunes, 18 de febrero de 2008 18:17
>>> Para: Hans Castorp
>>> Hans,
>>> GIF supports only 256 colors. Use PNG (or JPG) for an
output format.
>>> Brent Fraser
>>>> Hi to all,
>>>> I'm trying to publish a cartography using both
vectorial and raster
>>>> layers.
>>>> I'm using mapserver 5 and agg_q as output format. There
is no problem
>>>> about
>>>> vectorial files (shapefiles): all work fine.
>>>> The only problem I'm having is trying to publish some
raster stuff: an
>>>> aerial photo (.geotiff) and a digital terrain model
(.ecw). I'm not
>>>> capable
>>>> to make the output showing real colours; there is an
example attached
>>>> to
>>>> this mail (an aerial photo).
>>>> My mapfile looks in this way:
>>>> LAYER
>>>> NAME "MDT"
>>>> STATUS DEFAULT
>>>> GROUP "MDT"
>>>> TYPE raster
>>>> DATA "mdt.tif"
>>>> CLASS
>>>> MINSCALE 15000
>>>> END
>>>> END
>>>> LAYER
>>>> NAME "ORTOFOTO"
>>>> STATUS DEFAULT
>>>> GROUP "ORTOFOTO"
>>>> TYPE raster
>>>> DATA "ortofoto.ecw"
>>>> CLASS
>>>> MAXSCALE 15000
>>>> END
>>>> END
>>>> What I have to do to solve this?
>>>> Thanks in advance to everyone.
>>>> Hans Castorp
>>> No virus found in this incoming message.
>>> Checked by AVG Free Edition.
>>> Version: 7.5.516 / Virus Database: 269.20.7/1285 -
Release Date:
>> 18/02/2008
>>> 5:50
>>> No virus found in this outgoing message.
Release Date:
>> 18/02/2008
>>> 5:50
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 74 91 95 20
> Site web : http://www.neogeo-online.net
> Version: 7.5.516 / Virus Database: 269.20.7/1285 - Release
Date:
> 18/02/2008
> 5:50
Date:
> 18/02/2008
> 5:50
Version: 7.5.516 / Virus Database: 269.20.7/1286 - Release
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
