[mapserver-users] Netcdf / WCS
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 19 11:08:01 EST 2008
vincent wrote:
> Hello,
> I would like to create Web Coverage Service from one netCDF file in
> following http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
> My netCDF store rainfall matrix every five minutes in the "pluie"
> variable. This the CDL :
> dimensions:
> time = UNLIMITED; // (496 currently) // (has coord.var)
> x = 50; // (has coord.var)
> y = 50; // (has coord.var)
> variables:
> int Lambert_Conformal;
> :grid_mapping_name = "lambert_conformal_conic";
> :standard_parallel = 43.20317, 44.99683; // double
> :longitude_of_central_meridian = 2.337229; // double
> :latitude_of_projection_origin = 44.1; // double
> :false_easting = 600.0; // double
> :false_northing = 3200.0; // double
> :_CoordinateTransformType = "Projection";
> :_CoordinateSystems = "ProjectionCoordinateSystem";
> :_CoordinateAxes = "y x";
> :_CoordinateAxisTypes = "GeoX GeoY";
> * double pluie(time=496, y=50, x=50);*
> * :units = "mm/h";*
> * :long_name = "Intensité de pluie";*
> * :coordinates = "lat lon";*
> * :grid_mapping = "Lambert_Conformal";*
> * :_CoordinateSystems = "ProjectionCoordinateSystem LatLonCoordinateSystem";*
Vincent,
Because GDAL treats this array as a single dataset having 496 bands, I don't
believe there is a way to properly create a tileindex with one entry per
time slice, referring back directly to that band though this is something that
I think was discussed at one point.
You *can* serve the pluie array, but it will be represented as having 496
bands along a dimension called Band instead of time.
Hopefully Steve will correct me if I am wrong. What would be nice
is a way to have WCS (and raster rendering in general) potentially
override the BANDS= processing option with information read from a
tile index, and then update the gdaltindex program accordingly to
generate such results. This shouldn't - in theory - be too hard to
implement.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
