[MAPSERVER-USERS] thread safety
rich.fromm
nospam420 at yahoo.com
Tue Feb 19 14:17:41 EST 2008
rich.fromm wrote:
> inevitably if I throw enough requests at mapserver, it
> always crashes and brings down tomcat, usually within about an hour or
> two.
After searching around the mailing list archives a bit more, I am beginning
to
suspect that this may be caused by the JVM gc, and maybe improper use of
delete() within mapscript:
http://www.nabble.com/Re%3A--UMN_MAPSERVER-USERS---mapserver--Java-VM-Crashes-using-the-Mapscript-API-to1548675.html#a1548675
http://www.nabble.com/mapscript-jvm-crash-on-removeLayer-to6206628.html#a6206628
>From reading through those threads, it's still not clear to me under
precisely
what circumstances it is necessary to call delete() on a java mapscript
object, and under what circumstances it is sufficient to let the garbage
collector handle it. But examing my code further, I do appear to be
inconsistent. Here is a simplified version of pseudo-code showing my object
creations and deletions:
--- begin ---
mapObj map = new mapObj();
pointObj pt1 = new pointObj();
pointObj pt2 = new pointObj();
rectObj rect = new rectObj();
for (i ...) {
layerObj layer = map.getLayer(i);
for (j ...) {
classObj class = layer.getClass(j);
labelObj label = class.getLabel();
imageObj img = map.draw();
img.delete();
map.delete();
--- end ---
Specifically I am NOT calling delete() on either of the pointObj's, on the
rectObj, on the layerObj in the outer loop, or on the classObj or labelObj
in
the inner loop.
I am going to try inserting the maximum number of applicable delete()'s and
see if that helps.
- Rich
View this message in context: http://www.nabble.com/thread-safety-tp15514019p15562408.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
