re[MAPSERVER-USERS] ad angle from database to rotate symbol ->
Symbol definition error
Käpt'n Haddock
saperlipopette at gmx.ch
Wed Feb 20 02:54:08 EST 2008
YA, thank you very much for your help! Things work as expected if I write
ANGLE [orientation] # orientation being the name of the column of the
postgis-table
Thanks!
I do find it confusing that declaring the column-name with the data
works differently for different options
LABELITEM "columnname" # LABELITEM [columnname] won't work
ANGLE [columnname] # ANGLE "columnname" won't work
How could I have figured this out myself? Which part of the
documentation did I miss?
best regards
paul
Yewondwossen Assefa schrieb:
> Paul,
> I think the syntax for attribute binding is something like
> ANGLE [orientation] (attribute value in brackets). Could you try
> changing you map file and give it a try.
> Best Regards,
> Paul L wrote:
>> Dear List
>> I'm not the first one to ask this question, but I am unable to use
>> the older
>> list-posts as in the meantime (mapserver 5.0) the ANGLEITEM seems to be
>> deprecated, if I understand this document
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
>> correctly.
>> I am reading points from a postgis-table and would like Mapserver to
>> rotate
>> the symbols of each point according to the rotation-value stored as
>> integer
>> in the same table. It works fine as long as I hardcode the angle like
>> "ANGLE=45". As soon as I try setting ANGLE="orientation" I get the
>> errormessage:
>> getSymbol(): Symbol definition error. Parsing error near
>> (orientierung):(line 126)
>> Can you help me find my errors?
>> Thank you very much
>> Paul
>> P.S. I can actually read the angle and display it as a label, so it
>> shouldn't be a problem of reading from the database.
>> LAYER
>> NAME points
>> TYPE POINT
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "dbname=test_postgis user=postgres password=postgres
>> host=localhost port=5432"
>> DATA "geometry from (select id, name, orientation, geometry from
>> points)
>> as foo USING UNIQUE id USING SRID=-1"
>> STATUS DEFAULT
>> TRANSPARENCY 65
>> CLASS
>> STYLE
>> SYMBOL "U"
>> SIZE 15
>> COLOR 0 0 150
>> ANTIALIAS TRUE
>> ANGLE 45
>> #ANGLE "orientation" #throws error: getSymbol(): Symbol
>> definition error
>> END
>> END
>> END
