[mapserver-users] Trouble Importing Layer from Web Feature Service
John Schattel
John.Schattel at noaa.gov
Thu Feb 21 16:00:12 EST 2008
I am trying to test our Web Feature Service (WFS) using MapServer as a
WFS client. I am using the layer definition shown below in the .map
file. The request sent by MapServer looks good (see below layer
definition) and the response from the WFS looks good (for brevity sake,
I'm only including a couple of the features returned). When I try to
turn on the layer in Chameleon 2.4
(http://localhost/chameleon/samples/sample_ogc.phtml), I get a red X
where the image should be. Is this a case where MapServer doesn't
support the XML it is receiving? If so, can anyone tell me what aspect
of the XML is giving MapServer problems?
In advance, thanks for any help you can offer as I try to get MapServer
and the our WFS to work together.
John
LAYER
NAME NDFD
GROUP "VECTOR"
TYPE POINT
STATUS OFF
# this is a remote OGC:WFS
CONNECTIONTYPE WFS
# the server URL prefix
# MapServer will add the OGC:WMS specific
# keyword value pairs accordingly
#CONNECTION
"http://map.ns.ec.gc.ca/envdat/map.aspx?service=WFS&version=1.0.0&request=GetFeature"
CONNECTION
"http://www.weather.gov/mdl/survey/pgb_survey/dev/OGC_services/ndfdOWSserver.php"
PROJECTION
"init=epsg:4326"
END
# base info MapServer needs to know to generate the
# OGC:WFS GetFeature request
METADATA
# MapServer default sends POST
# force to GET
# "wfs_request_method" "GET"
# how long (in seconds) should MapServer use
# in issuing and receiving the data?
"wfs_connectiontimeout" "60"
# Filter to get a small amount of NDFD data
"wfs_filter"
"<PropertyName>wx</PropertyName><PropertyName>maxt</PropertyName>"
# which version of the OGC:WFS should MapServer communicate with
"wfs_version" "1.0.0"
# service type for connection
# this info is a bit redundant
"wfs_service" "WFS"
# what is the feature type you are querying
"wfs_typename" "Forecast_Gml2Point"
# what is the spatial extent?
"wfs_latlonboundingbox" "-121.2 20.2 -60.89 50.0"
END
# MapServer will then use this information to generate a string like:
http://map.ns.ec.gc.ca/envdat/map.aspx?version=<wfs_version>&service=<wfs_service>&request=GetFeature&typename=<wfs_typename>
# missing required keyword value pairs get generated according
# to the application using this mapfile, i.e.:
# &bbox, &filter, etc.
END
MapServer sent request
<?xml version="1.0" ?>
<GetFeature
service="WFS"
version="1.0.0"
outputFormat="GML2">
<Query typeName="Forecast_Gml2Point">
<Filter><PropertyName>wx</PropertyName><PropertyName>maxt</PropertyName></Filter></Query>
</GetFeature>
GML returned by WFS to MapServer
<app:NdfdForecastCollection
xmlns="http://www.weather.gov/mdl/survey/pgb_survey/dev/OGC_services"
xmlns:app="http://www.weather.gov/mdl/survey/pgb_survey/dev/OGC_services"
xmlns:ows="http://www.opengis.net/ows"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.weather.gov/mdl/survey/pgb_survey/dev/OGC_services
http://www.weather.gov/mdl/survey/pgb_survey/dev/OGC_services/schema/dwGML_WFS_GMLv212.xsd
<gml:boundedBy>
<gml:Box srsName="EPSG:4326">
<gml:coordinates>13.48,-176.65 71.30,145.72</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<app:Forecast_Gml2Point>
<gml:position>
<gml:Point srsName="EPSG:4326">
<gml:coordinates>-97.6,35.4</gml:coordinates>
</gml:Point>
</gml:position>
<app:validTime>2008-02-20T23:36:00</app:validTime>
<app:maximumTemperature>44.0</app:maximumTemperature>
<app:weatherCoverage>chance</app:weatherCoverage>
<app:weatherIntensity>light</app:weatherIntensity>
<app:weatherType>drizzle</app:weatherType>
<app:weatherQualifier>none</app:weatherQualifier>
<app:weatherVisibility>none</app:weatherVisibility>
</app:Forecast_Gml2Point>
</gml:featureMember>
<gml:featureMember>
<gml:position>
<gml:coordinates>-95.9,36.2</gml:coordinates>
</gml:Point>
</gml:position>
<app:maximumTemperature>37.0</app:maximumTemperature>
<app:weatherCoverage>patchy</app:weatherCoverage>
<app:weatherType>freezing drizzle</app:weatherType>
</app:NdfdForecastCollection>
