[MAPSERVER-USERS] annotation layer
rich.fromm nospam420 at yahoo.com
Fri Feb 22 12:36:35 PST 2008
Hans Castorp wrote:
> It is possible to have an annotation layer with symbol but without label??
I think you could do it.
For example, I have a layer for highway shields that follows the sort of
pattern below.  The CLASSITEM defines which symbol to use (when it matches
the
EXPRESSION), and the LABELITEM puts the highway number of the shield
(subject
to the description in the LABEL).
If you just didn't have a LABEL section, and/or a LABELITEM, or the label is
just "", then I would think that you could accomplish what you desired.  But
I
haven't tried, so I don't know if there are maybe some complications.  Good
luck.
- Rich
  LAYER
    TYPE       ANNOTATION
    CLASSITEM  type
    LABELITEM  num
    CLASS
      EXPRESSION type
      STYLE
      END
      LABEL
      END
    END
    CLASS
    END
  END
View this message in context: http://www.nabble.com/annotation-layer-tp15608515p15641531.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users mailing list
