Antwort: Re: [mapserver-users] Strange line in picture
umn-ms at hydrotec.de
Mon Feb 25 07:10:32 EST 2008
Once again on this.
I wrote, that the problem would be solved in 5.0.2.
That's wrong. In my tests I mixed up GD/AGG.
With GD2.0.35/MS 5.0.2 bug is still there and is still reproducible with
the testcase.
Sorry for confusion
Benedikt Rothe
mapserver-users-bounces at lists.osgeo.org schrieb am 24.02.2008 19:04:56:
> I repeated the test with 5.0.2.
> Error doesn't occure. Seems to be solved.
> Bye
> Benedikt Rothe
> Gregor Mosheh <gregor at hostgis.com> schrieb am 24.02.2008 18:23:10:
> > umn-ms at hydrotec.de wrote:
> > > In some cases Mapserver produces an unwanted and strange horizontal
line
> > > at the bottom of a map, if a point is rendered near the bottom.
> > If the answer is the same as when I noted this some months ago:
> > That's a known GD+Mapserver bug. But strangely I didn't find this bug
in
> > the MS Trac; not that I looked very hard.
> > Try AGG, or grab the latest Subversion version of Mapserver. Then
again,
> > the fix may be in 5.0.1 by now.
> > Gregor Mosheh / Greg Allensworth, BS, A+
> > System Administrator
> > HostGIS cartographic development & hosting services
> > http://www.HostGIS.com/
> > "Remember that no one cares if you can back up,
> > only if you can restore." -
> AMANDA_______________________________________________
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080225/7c2257e3/attachment.html
