[mapserver-users] Re: Problems with embedded legend after upgrade
to 5.0.2 (Perl MapScript)
Roberto Bianconi
roberto.bianconi at gmail.com
Tue Feb 26 13:22:47 EST 2008
I did answer myself (at least now it works fine again), sorry:
$map->{legend}->{position} = $mapscript::MS_UR;
On Tue, Feb 26, 2008 at 6:54 PM, Roberto Bianconi
<roberto.bianconi at gmail.com> wrote:
> Hello,
> I have a Perl script where - with Mapscript - I first generate an
> image and then I embed it into a
> larger image, so that I can print on the right a legend for the emebedded image.
> Printing the legend on the right side is the last step, with these
> lines of code ($map is a mapObj):
> $map->{legend}->{position} = 2;
> $map->embedLegend($img);
> $map->drawLabelCache($img);
> $img->save($image_file);
> With older Mapserver versions it worked nicely and the legend was
> printed at the upper right.
> Now with version 5.0.2 the legend is always embedded on the upper LEFT
> corner, and the left half is missing.
> Is there any version change that might cause this behaviour with the
> above code lines ?
> Thank you for any hint.
> Roberto
