[mapserver-users] Dynamic mapping with CGI parameters
Milo van der Linden
mlinden at zeelandnet.nl
Tue Feb 26 16:20:43 EST 2008
Hello Colin,
as I tried to clear to you before, I would go for option 2! Better
still, I am using option 2 in a lot of real life cases.
Add userid=1234 to the request string (and as you say, pass it through
perl to sanitize, excelent choice)
And use:
DATA "line FROM (
SELECT num, id, line
FROM jsview_journeyroutes
WHERE us_id = %userid%
) AS foo USING UNIQUE id USING SRID=4326"
I can guarantee you that will work.
Kind regards,
Milo van der Linden
Colin Wetherbee schreef:
> Greetings.
> I have a fledgling MapServer application that uses PostgreSQL as its
> back-end. Each set of data I would like to retrieve from PostgreSQL
> is specific to a certain user. Currently, since the application is
> only in an alpha phase, I have MapServer retrieve the aggregate sum of
> the data in the database and display it on my map. This isn't going
> to work for the real application, since different users need to see
> different sets of data.
> I would like to do one of two things, but I've been poring over the
> documentation today and can't find any way to achieve either. I would
> very much appreciate some assistance. My two approaches are as
> follows, but if there are others, I would certainly be open to
> implementing something different.
> Approach #1:
> Since my application is written in Perl, I could use MapScript in Perl
> to generate bits of maps and return them to the browser as needed.
> Perl would interpret cookies and perform session authentication before
> generating a customized map file to pass along to MapServer. The Perl
> code [0] would look something like:
> sub GetMapPiece()
> $req = new mapscript::OWSRequest();
> $req->setParameter("SERVICE", "WMS");
> $req->setParameter("VERSION", "1.1.0");
> $req->setParameter("REQUEST", $something);
> # The next two lines are the important ones...
> my $mapFile = GenerateMapFile({ userid => $someUserId });
> my $mapObj = new mapscript::mapObj($mapFile);
> mapscript::msIO_installStdoutToBuffer();
> my $dispatch_out = $map->OWSDispatch($req);
> return mapscript::msIO_getStdoutBufferString();
> The problem with this is that, as far as I can tell, I can't create a
> mapObj from anything other than a file on disk. I would like $mapFile
> to contain the full text of a dynamically created map file, and I
> would then like to be able to create a new mapObj from it. My
> imaginary GenerateMapFile() function would generate the text for the
> map file, but it would never be saved to disk.
> Approach #2:
> This would be my preferred method, but from what I've read, I think
> approach #1 is more likely to happen.
> This approach entails passing a CGI parameter to mapserv that could be
> substituted somewhere in the map file. For example, the URL could be:
> http://example.com/cgi-bin/mapserv?userid=1234
> Then, the map file could contain something like:
> DATA "line FROM (
> WHERE us_id = {userid}
> And, MapServer would see "WHERE us_id = {userid}" and, for {userid},
> substitute the 1234 that was passed into mapserv as a CGI parameter.
> Of course, doing this directly would cause nasty SQL injection attack
> problems, but I could properly sanitize the input with Perl. No big
> deal there.
> End Approaches.
> Any thoughts on this?
> Thanks.
> Colin
> [0] Adapted from
> <http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript/#perl-example>.
> mapserver-users at lists.osgeo.org
