[mapserver-users] Re: Query Regrading Map Server
Kunal Malik
kunal.malik81 at gmail.com
Wed Feb 27 00:54:15 EST 2008
Hi Vishal!!
1.
As far as the compatibilty with the opengl is concerned i am asking this
because my display module is made on opengl and i have to display the raster
& the vector image on it.....
2.
we don't have to use the web-server as our application will run on intranet
..we want that mapserver to interact with opengl..
32 client take the map from the central map server and display on their
screen which is on opengl..
can u suggest ..how should i approach this ..i don;t have any idea about the
mapserver programming is concerned...
can u suggest any sample code which i could run on my machine so as to check
the compatibilty,
or any docs that u can refer ..
3.
I was looking for the grass option ..Do u have any idea ..that does grass
also need the mapserver to maintain the repository of data.,,
Looking forward for ur Reply.
Thanks
On 2/27/08, vishal nagpal <vishu73ns at gmail.com> wrote:
> Hi Kunal,
> 1. I do not have much experience on grass. but i hv read a little about
> it.
> 2. All the six requirements mentioned below can be done with both Grass
> and Mapserver.
> 3. What I know, GRASS is a very good and exhaustive software.
> Mapserver also has lot of features that GRASS has.
> 3. Mapserver is an ideal solution if you wish to use web based service.
> However, it also works on a Server-client model also.
> 4. I am not too sure why you need compatibility with OpenGL. Probably you
> wish to see the data in 3D. Both these servers represent data in 2D only.
> all the best
> Regards,
> Vishal
> On Tue, Feb 26, 2008 at 7:01 PM, Kunal Malik <kunal.malik81 at gmail.com>
> wrote:
> > Hi Vishal !!
> > I am working on Grass Tool & also Looking for map-server.
> > I have following requirement.,.
> > 1)Importing of Raster & Vector Maps.
> > 2) Re-Projection
> > 3)Create & Edit layer.
> > 4)Display Maps
> > 5)Set Transparency
> > 6)Stiching of Maps
> > and so on..
> > I have to use the GIS feature,,
> > I am told to look all this on open-source tool,,,so i am looking it on
> > Grass and Mapserver..my display is on OpenGL..also i have to take care that
> > tool i use should work with opengl..
> > can u suggest that going for grass & Mapserver..would able to resolve
> > all the requirements.
> > Thanks
> > On 2/26/08, vishal nagpal <vishu73ns at gmail.com> wrote:
> > > hi i hv seen ur queries in mapserver list how can i help u. i hav been
> > > wkg on mapserver for around six months now,
> > > Regards,
> > > Vishal
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080227/02b12a22/attachment.html
