[mapserver-users] WFS and typename issue
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Feb 28 16:43:44 EST 2008
Actually, I don't think spaces are allowed in XML element or attribute
names at all. Testing this in XMLSpy verifies this.
..Tom
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Pericles S. Nacionales
> Sent: 28 February, 2008 4:29 PM
> To: Fischer, Brian
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] WFS and typename issue
> The WFS 1.0.0 doesn't specifically say not to use spaces in a
> typeName but all the examples don't contain spaces... The
> space character always causes problem as part of a parameter
> in web forms, it should be avoided. That said, if the
> solution is as simple as escaping spaces in MapServer's GML
> output then maybe it should be done.
> It's not just spaces either... any special character could
> potentially be problematic (and maybe a potential security
> hole). So, yes, you probably should tell the WFS service
> author that it's bad karma to put spaces in typeNames and
> featureIDs. :) Add underscores or remove spaces if possible.
> -Perry
> Fischer, Brian wrote:
> > After troubleshooting this a little further here is what I found.
> > I get an invalid http request error if I try using an
> escape character
> > with a & in it. That is understandable.
> > If I try using + or %20 it gets a little further and this
> is the error
> > I get.
> > "msDrawMap(): Image handling error. Failed to draw layer named
> > 'hydrowfs'. msOGRFileOpen(): OGR error. Open failed for OGR
> connection
> > `C:/ms4w/tmp/ms_tmp/ccc2661b5c5cc4dbff3d2d052e2e73c7.tmp.gml'. XML
> > Parsing Error: Expected equal sign "
> > Also when I try opening the .gml file in Gaia 3 it says there is an
> > error reading the GML file. If I got through the GML file
> and remove
> > all the spaces from the typename and save the file. Then
> it opens fine.
> > It appears the problem is that MapServer is not escaping the space
> > character in the temporary GML file when it creates it. I
> don't know
> > a lot about the rules for the GML file and if a spaces are
> allowed or
> > what the escape character should be. I guess my simpliest
> solution is
> > to try to get the WFS service author to remove the spaces
> from their typenames.
> > But I would be willing to report this as a bug in MapServer
> if this is
> > really a bug. Hopefully someone can let me know.
> > Thanks,
> > Brian
> > Brian Fischer
> > Houston Engineering, Inc.
> > Maple Grove, MN
> > (763) 493-4522
> > From: Milo van der Linden [mailto:mlinden at zeelandnet.nl]
> > Sent: Thursday, February 28, 2008 2:38 PM
> > To: Fischer, Brian
> > Cc: Pericles S. Nacionales; mapserver-users at lists.osgeo.org
> > Have you tried using ?
> > I had some sort of issue that looks like yours.
> > like this:
> > "gml_include_items" "MFIELD,KFIELD,DFIELD"
> > "gml_MFIELD_alias" "A Field for M"
> > I can retrieve fieldnames with spaces on my installation of
> mapserver
> > for a WMS GetFeatureInfo request. If the same doesn't work on WFS I
> > would suggest filing a bug.
> > Fischer, Brian schreef:
> >> Just tried it and no + doesn't work. I also tried %20,   and
> >> Brian Fischer
> >> Maple Grove, MN
> >> (763) 493-4522
> >> From: Pericles S. Nacionales [mailto:naci0002 at umn.edu]
> >> Sent: Thursday, February 28, 2008 2:15 PM
> >> To: Fischer, Brian
> >> Brian,
> >> I take it the "+" character doesn't work?
> >> -Perry
> >>> Has anybody else experience problems when using a WFS
> service where
> >>> the typename has a space in it? I'm experiencing the WFS layers
> >>> that
> >>> don't have spaces work fine with MapServer, but ones that do have
> >>> spaces produce invalid GML files. Is there an escape
> character that
> >>> can be used to represent the space in the typename?
> >>> The WFS service I am trying to get to work is
> http://www.datafinder.org/wfsconnector/com.esri.wfs.Esrimap/MN_Metro
> >>> G
> >>> I
> >>> S_
> DataFinder_WFS_Water_Resources?request=getcapabilities&service=WFS&v
> >>> e
> >>> r
> >>> si
> >>> on=1.0.0
> >>> The layer without the space works fine, but the rest do not.
> >>> Thanks,
> >>> Brian
> >>> Brian Fischer, CFM
> >>> GIS Project Manager
> >>> Houston Engineering, Inc. | Leave Nothing to ChanceTM
> >>> 6901 East Fish Lake Road, Suite 140
> >>> Maple Grove, MN 55369
> >>> Phone: 763.493.4522 / Fax: 763.493.5572
> >>> Email: bfischer at houstonengineeringinc.com
> >>> <mailto:bfischer at houstonengineeringinc.com>
> >>> Website: www.houstonengineeringinc.com
> >>> <http://www.houstonengineeringinc.com/>
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
