[mapserver-users] msPOSTGISLayerGetShape(): Error
Paul Moen
pmoen at nd.gov
Fri Feb 29 10:27:20 EST 2008
Thanks Regina and Colin for the replies. I was hoping that I wasn't
imagining things. I will just add the cast until I install PosgreSQL 8.3.
Paul
On 2/29/08 7:54 AM, "Obe, Regina" <robe.dnd at cityofboston.gov> wrote:
> Actually I remember yeh back there was an automatic boolean cast put in
> the lwpostgis.sql. I think it was later removed because it was felt
> doing such things in Postgis was stepping out of bounds since that cast
> really has nothing to do with postgis and there is no internal
> dependency on it.
> Here is a thread about the issue
> http://postgis.refractions.net/pipermail/postgis-users/2007-October/0174
> 52.html
> I suspect maybe its because you are running a newer version of PostGIS
> (that I think has the cast removed where the cast was removed) not
> PostgreSQL that you are experiencing it.
> Hope that Helps,
> Regina
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul Moen
> Sent: Thursday, February 28, 2008 4:08 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] msPOSTGISLayerGetShape(): Error
> I just upgraded to postgres 8.2.6
> And postgis 1.3.2("POSTGIS="1.3.2" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel.
> 4.6.0, 21 Dec 2007" USE_STATS") and I get the following error.
> PHP Fatal error: [MapServer Error]: msPOSTGISLayerGetShape(): Error
> executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor2 BINARY
> CURSOR FOR SELECT
> "site_id"::text,"location"::text,"longitude"::text,"latitude"::text,"cou
> nty"
> ::text,"status"::text,"arb_siteno"::text,"last_name"::text,"first_name":
> :tex
> t,"add1"::text,"add2"::text,"city"::text,"state"::text,"zip"::text,"phon
> e"::
> text,"remarks"::text,"password"::text,"email"::text,"online_reporting"::
> text
> ,"x_coord"::text,"y_coord"::text,asbinary(force_collection(force_2d(geom
> NDR') from station WHERE site_id = 4243
> -ERROR: cannot cast type boolean to text, referer: http://10.8.54.31/
> : ..."::text,"latitude"::text,"county"::text,"status"::text,"arb_...,
> My table in postgresql is
> CREATE TABLE station
> site_id integer NOT NULL DEFAULT 0,
> "location" character varying(14) NOT NULL DEFAULT '',
> longitude double precision NOT NULL DEFAULT 0,
> latitude double precision NOT NULL DEFAULT 0,
> county character varying(30) NOT NULL DEFAULT '',
> status boolean NOT NULL DEFAULT false,
> arb_siteno character varying(5) NOT NULL DEFAULT '',
> last_name character varying(35) NOT NULL DEFAULT '',
> first_name character varying(20) NOT NULL DEFAULT '',
> add1 character varying(21) NOT NULL DEFAULT '',
> add2 character varying(21) NOT NULL DEFAULT '',
> city character varying(20) NOT NULL DEFAULT '',
> state character varying(2) NOT NULL DEFAULT '',
> zip character varying(9) NOT NULL DEFAULT '',
> phone character varying(10) NOT NULL DEFAULT '',
> remarks text NOT NULL DEFAULT '',
> "password" character varying(20) NOT NULL DEFAULT '',
> email character varying(80) NOT NULL DEFAULT '',
> online_reporting boolean NOT NULL DEFAULT false,
> x_coord integer NOT NULL DEFAULT 0,
> y_coord integer NOT NULL DEFAULT 0,
> geom geometry,
> My mapscript version is
> MapServer Version MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=EPPL7
> INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> PHP MapScript Version ($Revision: 7251 $ $Date: 2008-01-08 09:04:53
> -0800
> (Tue, 08 Jan 2008) $)
> All running on Mac OS 10.5.
> msPOSTGISLayerGetShape() tries to cast the status column to text, did it
> always do that?
> PostgreSQL 8.3 will have a type cast from boolean to text. But none of
> the
> earlier versions were supposed to.
> I can run the sql
> SELECT status::text from station
> with no errors in PostgreSQL 8.2.4 but not in 8.2.5 or 8.2.6, which
> leads me
> to believe that there was in a cast from boolean to text in 8.2.4.
> I never added a custom cast to do this before, so I am wondering if the
> only
> thing that changed is PostgreSQL? Can anyone confirm that there was a
> cast
> for boolean to text in PostgreSQL 8.2.4?
> Thanks,
> Paul
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
