SSL issues with mapserver
Josh Livni
mailing_lists at UMBRELLACONSULTING.COM
Fri Jan 4 17:34:24 EST 2008
I think this is more a general apache/browser question.
However, since you're here: it seems to work as expected. Eg when I go
to https://mgleahy.dyndns.org/ (which is where your certificate is for),
it does not have the second warning you note in your email. If you want
to get rid of the first warning, you will probably need to purchase a
certificate from a source that is trusted by your browser.
You'll probably get better responses to any followups on a different
list, however, as this is definitely not mapserver related.
-Josh
Crystal Li wrote:
> Hi All,
> I am using:
> - Apache version 2.0.58
> - PHP version 4.4.3-dev
> - MapServer 4.8.3 CGI and MapScript (CSharp, Java, PHP,
> Python)
> - support GD 2.0.33, FreeType 2.1.10, GDAL/OGR 1.3.2,
> PROJ, WMS/WFS, Flash, PDF, ECW3.1, PostGIS, GEOS,
> libcurl 7.15.0
> and download SSL related files from
> http://hunter.campbus.com <http://hunter.campbus.com/>, upload to my
> server.
> and add
> LoadModule ssl_module modules/mod_ssl.so
> <IfModule mod_ssl.c>
> Include conf/ssl.conf
> </IfModule>
> to httpd.conf,
> But I get error when I access to this website:
> The security certificate presented by this website was not
> issued by a trusted certificate authority.
> The security certificate presented by this website was issued
> for a different website's address.
> Security certificate problems may indicate an attempt to fool
> you or intercept any data you send to the server.
> I am attaching the files. please give me suggest, where should I
> modify to get rid of this, Really appreciate your time and help!
> Crystal
> ---------- Forwarded message ----------
> From: *Crystal Li* <crystal.li at idisis.com <mailto:crystal.li at idisis.com>>
> Date: Jan 4, 2008 3:18 PM
> Subject: SSL files
> To: Crystal Li crystal.li at idisis.com <mailto:crystal.li at idisis.com>
> Crystal Li
> Systems Analyst
> Idisis, Inc.
> 430, 318 11th Avenue S.E .
> Calgary, Alberta T2G 0Y2
> www.idisis.com <http://www.idisis.com>
> E-mail: crystal.li at idisis.com <mailto:crystal.li at idisis.com>
> Office: (403)670-7351
> Fax: (403) 670-7359
