MWF GetFeatureInfo problem solved
nelson guda
nelson.guda at GMAIL.COM
Sun Jan 6 12:42:14 EST 2008
It works! Thanks much!
That was definitely the issue. Thanks also to Josh for spending a
lot of time trying to help me figure this out.
Here is a summary of the problem for the record:
I was trying to get the WMS GetFeatureInfo request working on my
mapserver copy. I kept getting a response that looked like this:
> GetFeatureInfo results:
> Layer 'ira_fill2'
> Feature 689:
The solution was to put 'wms_include_items' 'all' in the METADATA
block for the layer.
You can see the results here: http://roadlessland.org
It is a site that allows users to get info about inventoried roadless
areas in US Forest Service lands. The spatial data is a shapefile
that is about 32mb. The site uses Google maps and overlays the map
with a wms layer from mapserver. User clicks on the map are
processed with a GetFeatureInfo request to mapserver.
Thanks for all your help, everyone.
nelson
On Jan 6, 2008, at 9:35 AM, Arnd Wippermann wrote:
> Hi Nelson,
> put this
> in the METADATA block for your layer.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/ginfo/
> Von: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU] Im Auftrag von nelson guda
> Gesendet: Freitag, 4. Januar 2008 22:59
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] WFS request options
> Thanks Josh,
> I looked over the WMS GetFeatureInfo request, and this is exactly
> what I need. For some reason, though the only data I am getting
> back looks like this:
> Layer 'ira_fill2'
> Feature 689:
> The feature number appears to correspond to the correct place in
> the dbf file, but none of the rest of the feature data is being
> returned. I don't understand. Does anyone have any ideas?
> thanks,
> nelson
> Here is the mapfile and request that I made:
> Request:
> http://thewildwoodstudios.com/cgi-bin/mapserv?map=../roadlessland/
> maps/
> ira.map&REQUEST=GetFeatureInfo&SERVICE=WMS&reaspect=false&VERSION=1.1.
> 1&LAYERS=ira_fill2&STYLES=default&FORMAT=image/
> gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:
> 4326&WIDTH=256&HEIGHT=256&QUERY_LAYERS=ira_fill2&x=254&y=165&BBOX=-122
> .16796875,46.37725420510028,-122.080078125,46.4378568950242
> Mapfile:
> MAP
> NAME "Roadless"
> STATUS ON
> SIZE 800 600
> STATUS ON
> EXTENT -124.40950012207 18.2457218170166 -65.7071533203125
> 49.0011405944824
> IMAGETYPE PNG
> SHAPEPATH "../shapefiles"
> FONTSET ../fonts/fonts.txt
> PROJECTION
> "init=epsg:54004"
> END
> WEB
> IMAGEPATH "/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "ira_wms"
> "wms_onlineresource" "http://thewildwoodstudios.com/cgi-bin/mapserv?
> map=../roadlessland/maps/ira.map&"
> "wms_srs" "EPSG:4326 EPSG:54004 EPSG:4269"
> END
> END
> LAYER
> NAME "ira_fill2"
> TYPE POLYGON
> METADATA
> "wms_title" "ira_fill2"
> "wms_srs" "EPSG:4326 EPSG:54004"
> END
> PROJECTION
> "init=epsg:4269"
> END
> DATA ira_by_name_nad83
> STATUS ON
> TRANSPARENCY 75
> LABELITEM "NAME"
> LABELMAXSCALE 1000000
> TEMPLATE "query.html"
> TOLERANCE 3
> TOLERANCEUNITS PIXELS
> DUMP TRUE
> CLASSITEM "ID"
> CLASS
> STYLE
> COLOR 0 255 0
> END
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> MINFEATURESIZE 40
> TYPE TRUETYPE
> FONT arial-narrow-italic
> SIZE 8
> ANTIALIAS TRUE
> POSITION cc
> PARTIALS FALSE
> MINDISTANCE 300
> WRAP '/'
> END
> END
> END
> END
> On Jan 4, 2008, at 10:48 AM, Josh Livni wrote:
>> Nelson,
>> Using this method, you don't want to make a WFS request - you want
>> to make a WMS request. The mapserver site has documentation on how
>> to set up your mapfile to respond to WMS requests (http://
>> mapserver.gis.umn.edu/docs/howto/wms_server) as well as the
>> template (which can be very simple for your use case).
>> There's a thread on the google groups list about using
>> getFeatureInfo, but since the guy's WMS is down it's probably not
>> the best example (though you could still look at his code).
>> http://openlayers.org/dev/examples/getfeatureinfo.html is another
>> example that you could probably start with for assistance on the
>> client side -- you'd need to modify it to work with Google Maps
>> (eg using Google's methods to get at their bbox and other criteria
>> while creating the queryUrl, and to parse the result) but the
>> concept is the same, so this should get you started.
>> Also - glad to hear my old comments helped on the roadlessland
>> site - it looks nice.
>> Cheers,
>> -Josh
>> PS - Please be sure to CC the mapserver list if this doesn't make
>> sense - others here may well have better ideas on how to help than
>> me, and chances are if you want to know something, others may be
>> in the same boat, and thus find the thread helpful.
>> nelson guda wrote:
>>> Hi again, Josh,
>>> I just tried "DescribeFeatureType", which works but the response
>>> only give the names of the variables. Any idea on how to get the
>>> actual data about those variables?
>>> many thanks,
>>> nelson
>>> DescribeFeatureType response:
>>> <element name="ira"
>>> type="ms:iraType"
>>> substitutionGroup="gml:_Feature" />
>>> <complexType name="iraType">
>>> <complexContent>
>>> <extension base="gml:AbstractFeatureType">
>>> <sequence>
>>> <element name="msGeometry" type="gml:GeometryPropertyType"
>>> minOccurs="0" maxOccurs="1"/>
>>> <element name="NAME" type="string"/>
>>> <element name="ID" type="string"/>
>>> </sequence>
>>> </extension>
>>> </complexContent>
>>> </complexType>
>>> On Jan 4, 2008, at 8:53 AM, Josh Livni wrote:
>>>> This doesn't answer you question exactly, but have you
>>>> considered using a WMS getFeatureInfo request instead? Then you
>>>> can use a simple template.html to decide which attributes you
>>>> want to return for later parsing. I've done this a few times
>>>> myself with Google Maps.
>>>> -Josh
>>>> nelson guda wrote:
>>>>> Hi all,
>>>>> I have an odd request regarding WFS capabilities. Is it
>>>>> possible to have a WFS mapserver request return gml results
>>>>> without the geometry data?
>>>>> I know that this seems odd, but it makes sense for what I am
>>>>> doing. I am using a WMS overlay to serve tiles for a large
>>>>> dataset to an overlay on google maps. In order to query
>>>>> specific polygons from that dataset (a shapefile), I am using a
>>>>> WFS GetFeature request. All I need is the id and other
>>>>> parameters of the feature, but not the geometry data (because
>>>>> it is already there from the WMS. Right now I am just parsing
>>>>> out the info I need from the gml at the server level, but it
>>>>> would be much faster if I could get the WFS to return only the
>>>>> feature info minus the geometry data. Is this possible?
>>>>> Thanks, and thanks for your previous help.
>>>>> nelson
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080106/9cee5629/attachment.html
