AGG: "fuzzy" lines at near horizontal/vertical angles ...
rich.fromm
nospam420 at YAHOO.COM
Tue Jan 8 12:54:26 EST 2008
Flavio Hendry wrote:
> AGG has to be 24bit.
I'm pretty sure that's not true. I'm using something like the following:
IMAGETYPE AGG_Q
OUTPUTFORMAT
NAME 'AGG_Q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "PALETTE_FORCE=TRUE"
# for why this is needed at all:
# http://trac.osgeo.org/mapserver/ticket/2096
# this must be an absolute path (should be able to be relative to
the map file for mapserver 5.2)
# http://trac.osgeo.org/mapserver/ticket/2115
FORMATOPTION "PALETTE=/absolute/path/to/colors.palette"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
which gives me (this is the result of running `file output.png`):
PNG image data, 640 x 480, 8-bit colormap, non-interlaced
- Rich
View this message in context: http://www.nabble.com/Polygon-style-with-outline-width-tp13586055p14694909.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
