forced palette and quantization for RGBA images
    Pål Kristensen
    pal.kristensen at STATKART.NO
    Wed Jan  9 06:31:05 PST 2008
Hi!
This is really god news, unfortunately there is still an issue regarding
this functionality in conjunction with the WMS transparent parameter. When
set to true, the resulting 8bit image has a black background, not
transparent as it should be.
Regards,
Pål Kristensen
tbonfort wrote:
> hi all,
> I committed the implementation to enable forced palette and color
> reduction via quantization for RGBA images. These options greatly
> reduce image size for png output when using IMAGEMODE RGBA.
> the tracking ticket is http://trac.osgeo.org/mapserver/ticket/2436 ,
> which contains examples of image size reduction you can hope to obtain
> when using the option
> you'll need a recent version of the mapserver source tree from SVN (
> instructions to obtain it:
> http://mapserver.gis.umn.edu/development/cvs/ )
> it is activated when the ./configure script is run with the
> --with-experimental-png switch, which checks for the libpng headers.
> this means that the libpng headers have to be installed and accessible
> on your system (apt-get install libpng-dev or the equivalent with
> yum/yast/etc...)
> to activate these outputs in your mapfiles you'll need to set some
> FORMATOPTION entries to the wanted OUTPUTFORMATs, eg
> to force quantization
> (creates a paletted png, with the palette automatically
> created/selected for each rendered image)
> OUTPUTFORMAT
>     NAME 'AGGAQ'
>     DRIVER AGG/PNG # not AGG specific, also works with GD. PNG is
> mandatory though
>     IMAGEMODE RGBA  # only for rgba imagemodes
>     MIMETYPE "image/png"
> # this is the important part
>     FORMATOPTION "QUANTIZE_FORCE=ON"
> # this specifies the number of colors wanted in the final image
> # 256 is the typically wanted value
> # values 17 to 255 are possible but don't really make sense as there's
> little reduction in file size compared to 256 (each pixel is still
> stored with 8 bits, only the palette is smaller)
> # 16 greatly reduces image size (and quality, no magic)
>     FORMATOPTION "QUANTIZE_COLORS=256"
> END
>  to use a specified precomputed palette
> (faster than quantization, and guarantees colors are consistent
> whatever the image created, but less flexible as the palette has to be
> precomputed and is fixed whatever is in the image)
> OUTPUTFORMAT
>     NAME 'AGGAP'
>     DRIVER AGG/PNG
>     IMAGEMODE RGBA
> # the important part
>     FORMATOPTION "PALETTE_FORCE=TRUE"
>     FORMATOPTION "PALETTE=/gro/jsigmaps/palette.txt"
> END
> here the palette file must be specified with an absolute path, and
> contains at most 256 lines, each consisting of an r,g,b,a quadruplet,
> eg:
> 0,0,0,0
> 127,127,127,2
> 196,226,251,237
> 170,170,170,2
> 191,191,191,4
> 196,225,251,233
> snip
> 163,189,242,57
> 137,158,242,56
> 118,137,241,48
> 184,213,245,75
> to obtain this palette, take a typical (32bit rgba png) image you will
> want to display, use your favorite image editor to reduce the number
> of colors (photoshop using "save web image" and selecting png, or the
> commandline utilities pngquant
> [http://libpng.org/pub/png/apps/pngquant.html] or neuquant
> [http://members.ozemail.com.au/~dekker/NEUQUANT.HTML], etc ) and then
> extract (and transform to the required r,g,b,a format) the computed
> palette to the palette file. ( pngcheck
> [http://www.libpng.org/pub/png/apps/pngcheck.html] with its -p option
> and some scripting can be used for this )
> these two options are still considered experimental, and any feedback
> you might give is welcome ( be it in the ./configure script,
> compiling, or image results )
> cheers,
> thomas
> ps: email sent for documentation purposes until the official
> documentation is created/released on the main documentation site
View this message in context: http://www.nabble.com/forced-palette-and-quantization-for-RGBA-images-tp14645870p14712888.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
