ANGLE follow
riteshambastha
ritesh.linux at GMAIL.COM
Wed Jan 9 11:07:58 EST 2008
Steve,
The best solution for today is to adjust the label on the basis of scales.
Regards,
Ritesh
Steve Lime wrote:
> It's a limitation in the algorithm at the moment and I don't have a good
> workaround.
> Steve
>>>> On 1/7/2008 at 1:56 PM, in message
> <546866.23450.qm at web45603.mail.sp1.yahoo.com>, Steve Smith
> <ssteve52 at YAHOO.COM>
> wrote:
>> I am using "ANGLE follow" to label elevation contours. When an elevation
>> value occurs on a tight curve, which is often, the numbers will overlap
>> each
>> other making it difficult to read. For instance if the value is 300, the
>> first 0 will overlap the 3 and the second 0 will overlap the first 0,
>> like a
>> deck of cards. Is there an option to prevent the letters from overlapping
>> each other, and still follow the line?
>> Thanks
>> Steve
>> Looking for last minute shopping deals? Find them fast with Yahoo!
>> Search.
View this message in context: http://www.nabble.com/ANGLE-follow-tp14674541p14715129.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
