AGG: "fuzzy" lines at near horizontal/vertical angles ...
rich.fromm
nospam420 at YAHOO.COM
Wed Jan 9 15:14:07 EST 2008
(not sure if I should be moving this to a different subject heading, as we're
veering a little off course here...)
tbonfort wrote:
> palette_force and quantize_force are mutually exclusive, in the sense
> that only one of them is applied (depending on which comes first in
> the mapserver code)
> * quantize_force is more flexible as it doesn't need to create a
> palette beforehand, but different colors can be seen from one map to
> another depending on the extent
> * palette_force produces more consistent results colorwise but a
> palette file has to be created beforehand. I'd recommend creating a
> palette with exactly 256 colors in it if you're looking for rendering
> speed, or with just the exact colors of your features if you're
> looking for rendering quality.
> On Jan 8, 2008 6:54 PM, rich.fromm <nospam420 at yahoo.com> wrote:
>> IMAGETYPE AGG_Q
>> OUTPUTFORMAT
>> NAME 'AGG_Q'
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> FORMATOPTION "PALETTE_FORCE=TRUE"
>> # for why this is needed at all:
>> # http://trac.osgeo.org/mapserver/ticket/2096
>> # this must be an absolute path (should be able to be relative to
>> the map file for mapserver 5.2)
>> # http://trac.osgeo.org/mapserver/ticket/2115
>> FORMATOPTION "PALETTE=/absolute/path/to/colors.palette"
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> END
I know for my purposes I want PALETTE_FORCE and PALETTE. Just to clarify,
given that, is the only specification above that you're complaining about
(and saying is useless) is QUANTIZE_FORCE ? Are QUANTIZE_DITHER and
QUANTIZE_COLORS not mutually exclusive with PALETTE_FORCE ?
I wish there were more concise documentation of the various FORMATOPTIONs.
I think I got the QUANTIZE_* stuff from:
http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics/view
and then the PALETTE* stuff came from some discussions on this mailing list.
But I don't recall any previous mention of mutual exclusivity. And I'm
wondering if there are other possibly relevant options that I'm ignoring out
of ignorance.
- Rich
View this message in context: http://www.nabble.com/Polygon-style-with-outline-width-tp13586055p14720466.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
