demo map
Pericles S. Nacionales
naci0002 at UMN.EDU
Wed Jan 9 15:28:12 EST 2008
Sounds like you have an older version of demo. Edit the index.html and
replace the following lines:
<select name="map_web_template" size="1">
<option value="itasca_basic.html"> Basic Application
<option value="itasca_adds_scalebar.html"> -- Adds
second scalebar
<option value="itasca_adds_pan.html"> -- Adds pan
controls
<option value="itasca_adds_frames.html"> -- Adds frames
<option value="itasca_adds_dhtml.html"> -- Adds
dhtml rubber-band box
</select>
with these:
<select name="map_web" size="1">
<option value="template itasca_basic.html"> Basic Application
<option value="template itasca_adds_scalebar.html">
-- Adds second scalebar
<option value="template itasca_adds_pan.html"> --
Adds pan controls
<option value="template itasca_adds_frames.html"> --
Adds frames
<option value="template itasca_adds_dhtml.html"> --
Adds dhtml rubber-band box
</select>
Also change these lines:
<input type="hidden" name="map_web_imagepath"
value="/ms4w/tmp/ms_tmp/">
<input type="hidden" name="map_web_imageurl" value="/ms_tmp/">
to these:
<input type="hidden" name="map_web" value="imagepath
/ms4w/tmp/ms_tmp/">
<input type="hidden" name="map_web" value="imageurl /ms_tmp/">
Look for RFC-31 for more info.
Cheers!
-Perry
MapServer wrote:
> Hello
> I have installed map server but while I am trying to test the demo map
> I get following error :
> Content-type: text/html msReturnPage(): Unable to access file. set in
> index.html
> and also I noticed that png files have been created in root of demo
> with following names:
> [root at firstone workshop-5.0]# ls -la set*
> -rw-r--r-- 1 apache apache 25840 Jan 9 11:57 set in
> -rw-r--r-- 1 apache apache 422 Jan 9 11:57 set in
> -rw-r--r-- 1 apache apache 353 Jan 9 11:57 set in
> -rw-r--r-- 1 apache apache 163 Jan 9 11:57 set in
> here is my changes to index.html located in workshop-5.0
> // EDIT THE NEXT 2 LINES TO MATCH YOUR SETUP
> var snippet = "IMAGEPATH '/var/www/html/workshop-5.0/tmp/'";
> snippet += " IMAGEURL '/tmp/'";
> snippet += " TEMPLATE " + template;
> document.demo.map_web.value = snippet;
> <input type="hidden" name="map"
> value="/var/www/html/workshop-5.0/itasca.map">
> <input type="hidden" name="program" value="/cgi-bin/mapserv">
> <input type="hidden" name="root"
> value="/var/www/html/workshop-5.0/">
