Pie Charts with Mapserver: Simple Perl code to create WKT Insert
statements for
Matthew Pettis
matthew.pettis at GMAIL.COM
Thu Jan 10 15:00:11 EST 2008
This is a solution, rather than a problem.
I had need for a pie chart with a clickable imagemap in a webpage where I
was also rendering maps with mapserver. I thought about looking for a tool
to do this for me, then decided to write a quick script to make a small
table in my postgis database that would have the necessary information to
draw the pie chart with mapserver. This code will generate a pie-ish chart
within a bounding box of (-1 -1 1 1). It is pie-ish because the sectors are
actually triangles, not true circle sectors. That could be modified, I had
over 100 segments, and that approximated a circle well enough for my
purposes.
I am submitting the perl code in case others have use for it. Trivial abuse
of mapserver, yes, but it was very handy for me -- perhaps it will be handy
for someone else.
Below the dotted line is the perl code.
Thanks,
Matt
#This perl code generates coordinate combinations using WKT to create
#a table whose geometry rendered by mapserver will create a pie-ish
#chart. It's not exactly a pie chart, as the pie wedges are triangles,
#not true circle sectors, but it's close enough for a large number of
#slices. Code should be easily modifiable to make more circular
#objects for low number of slices.
# config
my $PI = 3.1415926535897932384626433832795;
my $slices = 134; # number of pie slices
my $ccw = -1; # 1 is counter-clockwise, -1 is clockwise
my $phase = -$PI / 2.0; # phase shift of the starting point
# -$PI / 2.0 starts slice enumeration at the
# 12 o'clock position
# generate wkt coords of slices
for my $i (1 .. $slices) {
my $xy1
= sprintf(
"%5f %5f"
, cos (2 * $PI * ($i - 1) * $ccw / $slices - $phase)
, sin (2 * $PI * ($i - 1) * $ccw / $slices - $phase)
my $xy2
= sprintf(
"%5f %5f"
, cos (2 * $PI * $i * $ccw / $slices - $phase)
, sin (2 * $PI * $i * $ccw / $slices - $phase)
print "insert into temp values"
,"($i,GeometryFromText('POLYGON ((0 0, $xy1, $xy2, 0 0))',-1));"
, "\n";
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080110/8b5a42bf/attachment.html
