projection EPSG:4362 vs EPSG:29882
Peter Peterse
peter at PETERSE-UITHUIZEN.COM
Fri Jan 11 06:55:58 EST 2008
Hello all,
I'm having problems with the projection
<http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=4.2885413646778385,52.25793323942671,5.761033023649884,53.161245776968755>
and
<http://tol.han-dataport.nl/cgi-bin/mapserv?map=/data/osm.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:28992&WIDTH=500&HEIGHT=500&LAYERS=Wegen,Grens&STYLES=&TRANSPARENT=TRUE&FORMAT=image/png&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=80000,475000,180000,575000>
The coördinates should be the same. The bbox is an rect from 100 by 100 km
EPSG:4362 gives only a differend scalebar (150km)
I'v attached my map file (osm.map) with this message
Can anyone give me a clue whats going false?
regards,
Peter
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080111/05d0a873/osm.obj
