WFS requests ignore PostGIS columns beside the Geometry and
ID column
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Jan 14 08:58:47 EST 2008
What version of MapServer are you using?
As well, I see that you have set 'gml_include_items' to 'all '. If you remove the trailing space (i.e. 'all'), does that help?
Failing this, I suggest you submit a testcase offline (minimal mapfile/sample data), which I can help you with.
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of sg1
> Sent: 12 January, 2008 5:30 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] WFS requests ignore PostGIS
> columns beside the Geometry and ID column
> Hi everybody,
> i extracted ArcGIS feature classes to shapefiles and imported
> them into a PostGIS database.
> Then i formulated a simple WMS request - everything worked fine.
> Then I tried setting up a WFS request. I got some results,
> but somehow the result ignored every column but the gid and the_geom!
> actually the getcapabilities return no errors and also the
> getfeature returns with no errors, just the column attributes
> are missing!
> Up to now there's just one more column,that should be
> integrated too. It is called 'wegnr' - type is 'character varying'
> The interesting thing is, that the column is also missing
> when I use the Shapefile as data source.
> Schema, ns are default.
> Usually the column should be described by another <element />
> tab, but it's missing
> I can't find the error.
> As I can access the data in the database I thought it's a
> mapserver problem, but I'm not sure
> The describeFeatureType request looks as followed:
> <schema targetNamespace="http://mapserver.gis.umn.edu/mapserver"
> elementFormDefault="qualified" version="0.1"> <import
> namespace="http://www.opengis.net/gml"
> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
> <element name="wanderwege" type="ms:wanderwegeType"
> substitutionGroup="gml:_Feature"/>
> − <complexType name="wanderwegeType">
> − <complexContent>
> − <extension base="gml:AbstractFeatureType">
> − <sequence>
> <element name="msGeometry" type="gml:GeometryPropertyType"
> minOccurs="0"
> maxOccurs="1"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> <element name="wanderwege_shp" type="ms:wanderwege_shpType"
> − <complexType name="wanderwege_shpType">
> − <complexContent>
> − <sequence>
> minOccurs="0"
> maxOccurs="1"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> That's an extract of the layer in the Mapfile:
> LAYER
> NAME 'wanderwege'
> TYPE LINE
> CONNECTION 'user=postgres password=Si18JaudcTdW.
> dbname=postgis host=localhost port=5432'
> CONNECTIONTYPE POSTGIS
> DATA 'the_geom from wanderwege'
> DUMP TRUE
> STATUS OFF
> METADATA
> 'wms_title' 'wanderwege'
> 'wms_srs' 'EPSG:31285'
> 'wms_title' 'ww'
> 'wfs_title' 'ww'
> 'wfs_typename' 'ww'
> 'wfs_request_method' 'get'
> 'wfs_service' 'wfs'
> 'wfs_version' '1.0.0'
> 'wfs_extent' '392570 145627 578166 218654'
> 'wfs_featureid' 'gid'
> 'wfs_tname' 'wegnr'
> 'wfs_srs' 'EPSG:31285'
> 'gml_include_items' 'all '
> END
> END
> Thanks for every idea you guys have, I'm quite at my wits' end
> sg1
> http://www.nabble.com/WFS-requests-ignore-PostGIS-columns-besi
> de-the-Geometry-and-ID-column-tp14766031p14766031.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
