Data format problem - GDFOUT and SIFP
rich.fromm
nospam420 at YAHOO.COM
Mon Jan 14 14:55:07 EST 2008
meditor wrote:
> I've got some data today from Navteq, It's weird that i cannot open it
> with
> the GIS software I have, i thought i may open it with OGR/GDAL
> The data has the file extension: GDFOUT and SIFP
I also get data from Navteq. I don't bother with SIF, I think you might
need Navteq software to deal with that, and I wouldn't be surprised if it's
Windows only.
I get my data from them in *.shp files, and use shp2pgsql to convert them to
*.sql files that I can import into postgresql/postgis.
Navteq unfortunately doesn't make it very obvious that their data is even
available in SHP format. If you have access to
https://navteq.subscribenet.com/, what you want are the downloads labeled
NAVSTREETS ArcView. That gives you an ISO. Loopback mount it, and one of
the files it contains (most of the bits) should be a *.tar.gz file. And if
you gunzip and untar it, you'll find a bunch of sets of files, one set for
each table, and in each set should be a *.shp file.
View this message in context: http://www.nabble.com/Data-format-problem---GDFOUT-and-SIFP-tp14756434p14811690.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
