WFS requests ignore PostGIS columns beside the Geometry and
ID column
Milo van der Linden
mlinden at ZEELANDNET.NL
Tue Jan 15 12:37:13 EST 2008
My guess is that it is a windows related problem. I had it too. Sorry I
failed to read the list in time to help you with the answer.
sg1 schreef:
> Hi everybody,
> I use the ms4w package version 2.2.6.
> I tried your suggestions, but nothing helped, until - just because of pure
> frustration - i changed the ' signs to "
> So instead of 'gml_include_items' 'all'
> it's
> "gml_include_items" "all" now
> And this works!
> I don't know exactly why, maybe one of you can tell me if there is a
> significant difference in using different quotation marks?
> I knew it had to be a obvious error, but that is just...
> Thanks for your time and help!
> sg1
> Kralidis,Tom [Burlington] wrote:
>> What version of MapServer are you using?
>> As well, I see that you have set 'gml_include_items' to 'all '. If you
>> remove the trailing space (i.e. 'all'), does that help?
>> Failing this, I suggest you submit a testcase offline (minimal
>> mapfile/sample data), which I can help you with.
>> ..Tom
