edited image not being saved and displayed properly
SUBSCRIBE MAPSERVER-USERS mapuser map.user at YAHOO.COM
Thu Jan 17 02:10:58 PST 2008
hi,
how can i set the bounding box values, what is the bounding box? is it
not the same i.e. extent?
well the tutorial uses the url:
href="/cgi-bin/mapserv.exe?
map=/ms4w/apps/tutorial/htdocs/example1-
9.map&layer=states&layer=modis">Example 1.9- The difference
between map and browse mode</a>
it has not set any extent values initially, in the url. i am using the same
url.
i have also tried by setting the extent to the full extent of my table in
the mapfile. and it loads the full data initially, but with the same
problem of empty image being loaded on the click, and which is what is
saved in the tmp file.
i have altered the mapfile as u recommended. please clear the
bounding box problem.
thanks for helping
More information about the MapServer-users mailing list
