PostGIS connection
Begoña Gonzalez
begodom at GMAIL.COM
Thu Jan 17 07:57:39 EST 2008
Postgres is running with the postmaster.
When I try to connect access the database independent of mapserver there is
the following error message:
"Error connecting to the server: no se pudo conectar con el servidor:
Connection refused (0x0000274D/10061)
¿Está el servidor en ejecución en el servidor <<***.***.**.*>> y aceptando
conexiones TCP /IP en el puerto 5432?"
The server is runing so I suppose that the problem is with TCP/IP
connections but I´m not sure of this settings. How do i check the TCP/IP
connection of 5432 port?
Thanks
On Jan 17, 2008 11:47 AM, Steven De Vriendt <gisaalter at gmail.com> wrote:
> So, is postgres up and running with the postmaster ?
> Check if you can access the database independent of mapserver...
> Steven
> On Jan 17, 2008 11:04 AM, SUBSCRIBE MAPSERVER-USERS Bego D. <
> begodom at gmail.com> wrote:
> > Hello
> > We are new in Mapserver.
> > I have installed MapServer 4 Windows version 2.2.6 on my computer and in
> > another computer of my office we have installed Postgis 1.3.2. for 8.2
> > PostgreSQL.
> > Both works fine, we can work with Mapserver-Oracle Spatial or with .shp
> > or .tab, but now we want to connect MapServer with PostGis and we get
> > this
> > error:
> > msDrawMap(): Image handling error. Failed to draw layer named 'INFVIA'.
> > msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> > connect string 'host=****** dbname=**** user=postgres
> > password=****** port=5432'. Error reported was 'could not connect to
> > server: Connection refused (0x0000274D/10061) Is the server running on
> > host " 192.168.0.3" and accepting TCP/IP connections on port 5432? '.
> > This
> > error occured when trying to make a connection to the specified
> > postgresql
> > server. Most commonly this is caused by (1) incorrect connection string
> > (2)
> > you didnt specify a 'user=...' in your connection string (3) the
> > postmaster
> > (postgresql server) isnt running (4) you are not allowing TCP/IP
> > connection to
> > the postmaster (5) your postmaster is not running on the correct port -
> > if its
> > not on 5432 you must specify a 'port=...' (6) the security on your
> > system
> > does not allow the webserver (usually user 'nobody') to make socket
> > connections to the postmaster (7) you forgot to specify a 'host=...' if
> > the
> > postmaster is on a different machine (8) you made a typo
> > My .map is:
> > CONNECTIONTYPE POSTGIS
> > CONNECTION "host=***.***.**.* dbname=**user=postgres password=***
> > port=5432"
> > DATA "the_geom geometry from INFVIA2"
> > Any help will be appreciate.
> > Bego
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080117/924e6f30/attachment.html
