mapserver error
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jan 17 17:47:46 EST 2008
Shp2img works ok on the mapfile? Does apache work or is this IIS only?
>>> On 1/17/2008 at 3:04 PM, in message
<944DCD961F4CD649BCEBB52E3C929F6501863C4B at usd-am-xch-01.am.trimblecorp.net>,
Lee Keel <lee_keel at TRIMBLE.COM> wrote:
> Anyone else got a thought here? Or can tell me where to check the debug
> logs? I have turned DEBUG 5 in my map file but there is nothing in the log
> file other than "...... normal execution".
> Thanks in advance,
> LK
> ________________________________
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Sent: Thu 1/17/2008 2:56 AM
> To: Lee Keel
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] mapserver error
> strange...
> what version of mapserver are you using?
> can you (temporarily) turn off the angle follow of your labels and
> report if you're still having the same output problems
> thomas
> On Jan 16, 2008 8:03 PM, Lee Keel <lee_keel at trimble.com> wrote:
>> sorry, I hit enter before I meant to....
>> You can view the blurring problem at: <http://dev.uai.com:28080/public/blur>
> <http://dev.uai.com:28080/public/blur.html> .html
>> From: Ed McNierney [mailto:ed at topozone.com]
>> Sent: Wed 1/16/2008 12:13 PM
>> To: Lee Keel; MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: RE: [UMN_MAPSERVER-USERS] mapserver error
>> Lee -
>> INTERLACE=ON is not "wrong". Tim is pointing out that if you're viewing an
> interlaced output image, the first, alternating set of scanlines will be
> displayed and then your browser will start again at the top of the image,
> filling in the alternate interlacing lines. This will cause the top of the
> image to appear complete while the bottom is "blurry". You can see
> variations on these visual artifacts depending on your browser, and the
> effect is more pronounced over a slow connection.
>> But if the image still looks blurry at the bottom even after you're certain
> the image has been completely loaded, then this is not your problem.
>> It's hard to diagnose visual problems in text; can you either post the
> output image or (preferably) a public URL where the image can be viewed?
>> - Ed
>> Ed McNierney
>> Chief Mapmaker
>> Demand Media / TopoZone.com
>> 73 Princeton Street, Suite 305
>> North Chelmsford, MA 01863
>> ed at topozone.com
>> Phone: +1 (978) 251-4242
>> Fax: +1 (978) 251-1396
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Lee Keel
>> Sent: Wednesday, January 16, 2008 1:06 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Timothy,
>> Here are the OUTPUTFORMAT options I have in my map file. Do they look
> correct?
>> OUTPUTFORMAT
>> NAME "png"
>> MIMETYPE "image/png"
>> DRIVER "GD/PNG"
>> EXTENSION "png"
>> IMAGEMODE PC256
>> TRANSPARENT FALSE
>> FORMATOPTION "INTERLACE=OFF"
>> END
>> OUTPUTFORMAT
>> NAME "jpg"
>> MIMETYPE "image/jpeg"
>> DRIVER "GD/JPEG"
>> EXTENSION "jpg"
>> IMAGEMODE RGB
>> TRANSPARENT FALSE
>> END
>> OUTPUTFORMAT
>> NAME "gif"
>> MIMETYPE "image/gif"
>> DRIVER "GD/gif"
>> EXTENSION "gif"
>> IMAGEMODE PC256
>> TRANSPARENT FALSE
>> END
>> From: UMN MapServer Users List on behalf of Nolte, Tim
>> Sent: Wed 1/16/2008 11:49 AM
>> One quick thought that I have since you say that a layer image is
>> blurred on the bottom portion is that you have FORMATOPTION INTERLACE=ON
>> set. This turns on interlacing and sometimes I see that it takes a few
>> seconds on my mapserver to fully render the image. If you want to
>> prevent this blurring turn that setting off in your Mapfile.
>> Timothy J Nolte - tnolte at ilpcs.com
>> Associate Network Planning Engineer
>> iPCS Wireless, Inc.
>> 4717 Broadmoor Ave, Suite G
>> Kentwood, MI 49512
>> Office: 616-656-5163
>> PCS: 616-706-2438
>> Fax: 616-554-6484
>> Web: www.ipcswirelessinc.com
>> Behalf Of Lee Keel
>> Sent: Wednesday, January 16, 2008 11:38 AM
>> Subject: [UMN_MAPSERVER-USERS] mapserver error
>> Hello list. I am having a problem and it is beginning to look like
>> mapserver is behind it somehow. I am using ms4w 2.2.6 to render
>> postgres data to openlayers. Mapserver is configured to use IIS\CGI
>> instead of apache. I am actually having 2 problems, but I am not sure
>> that they are not related. One problem is that sometimes the server
>> just isn't returning any data for different layers to OpenLayers. I
>> have talked extensively with the OL guys and have come back to the fact
>> that if I take the URL that is requesting the information from
>> mapserver, then I get: "The specified CGI application misbehaved by not
>> returning a complete set of HTTP headers." The most consistent way I
>> can reproduce this is to zoom in real close. The second problem I am
>> having is that when I am getting layer images back, they are blurred on
>> the bottom portion. It looks like someone took a cloth and just wiped a
>> whiteboard.
>> I am about 5 days late on a deadline to have this up and running, so I
>> am open to try any suggestions that someone may have.
>> Thanks in advance,
>> Lee
