mapserver error
Lee Keel
lee_keel at TRIMBLE.COM
Fri Jan 18 10:21:26 EST 2008
Thanks Ed. I will do that. Was just trying not to cross post and hoping that there were enough of the OL guys on this list. But I will fwd on to OL list.
From: UMN MapServer Users List on behalf of Ed McNierney
Sent: Fri 1/18/2008 8:58 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] mapserver error
Lee -
While you might get info here, you should also post this to the
OpenLayers list to get info on "what's different in OL".
- Ed
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lee Keel
Sent: Friday, January 18, 2008 9:43 AM
Hello all.
I have a new twist to my problem that I believe rules
mapserver->postgres out. I added a layer last night that are the labels
for the roads and I am getting both problems with this layer now as
well. However, these labels are coming from TIGER shape files instead
of postgres.
Here is something else I have monkeyed with. If I use
http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map&layers=ba
semap+basemap_anno) then all of my layers seem to be working at any zoom
level. But if I go to my openlayers application, they don't always
work. If you get a layer not working in the OL app and check the URL,
it doesn't seem to be incorrect. So what is the difference between OL
requesting from mapserver based on a bbox and the HTML below requesting
an image from mapserver?
Sorry for my newby questions and 1,000s of emails, but just trying to
narrow this down.
Thanks,
LK
Map File Settings for WEB:
WEB
TEMPLATE 'gas.html'
IMAGEPATH "d:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "gas.log"
METADATA
wms_title "WMS"
wms_onlineresource
"http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map
<http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map> &"
"wms_srs" "EPSG:2238"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
end
END
Gas.HTML File that is being used:
<html xmlns="http://www.w3.org/1999/xhtml <http://www.w3.org/1999/xhtml>
<head>
<meta name="generator" content="HTML Tidy for Windows (vers 1st June
2004), see www.w3.org <http://www.w3.org <http://www.w3.org/> > " />
<title>MapServer Workshop (panamacity)</title>
<meta http-equiv="Content-Type" content="text/html; charset=us-ascii"
</head>
<body bgcolor="#FFFFFF" text="#000000">
<h3></h3>
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="get"
action="http://webserver/cgi-bin/mapserv.exe
<http://webserver/cgi-bin/mapserv.exe> " id="mapserv">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="[map]" />
<input type="hidden" name="imgext" value="[mapext]" />
<input type="hidden" name="imgxy" value="199.5 149.5" />
<table>
<tr>
<td>
<!-- SPECIFY MAP MODE -->
<div align="center">Map Mode:
<select name="mode">
<option value="browse">Browse</option>
<option value="map">Map</option>
</select>
Layers: <input type="TEXT" name="layers" value="[layers]" />
</div>
</td>
<td>
<!-- FORM SUBMIT BUTTON -->
<input type="submit" name="submit" value="Refresh" />
</div>
</td>
<td>
<!-- ZOOM/PAN CONTROLS -->
<div align="center">Map Control:
<select name="zoom">
<option value="4" [zoom_4_select]>Zoom In 4x</option>
<option value="3" [zoom_3_select]>Zoom In 3x</option>
<option value="2" [zoom_2_select]>Zoom In 2x</option>
<option value="1" [zoom_1_select]>Recenter</option>
<option value="-2" [zoom_-2_select]>Zoom Out 2x</option>
<option value="-3" [zoom_-3_select]>Zoom Out 3x</option>
<option value="-4" [zoom_-4_select]>Zoom Out 4x</option>
</select>
</div>
</td>
<td rowspan="2" valign="top">
<!-- <p>Reference:<br />
<img name="ref" src="[ref]" id="ref" />
</p> -->
<p>Legend:<br />
<img name="legend" src="[legend]" id="legend" />
</p>
</td>
</tr>
<tr>
<!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
<td colspan="3" align="center" valign="top">
<input type="image" name="img" src="[img]" width="800"
height="600" border="0" />
<table border="0" width="600" align="center">
<!-- DISPLAY THE SCALE BAR -->
<tr>
<td align="right"><!-- <img src="[scalebar]" /> --></td>
</tr>
</table>
</td>
</tr>
</table>
<input name="mapxy" type="text" value="[mapx] [mapy]" />
</form>
<p>Map scale 1:[scale]</p>
<p>Pixel size [cellsize]</p>
<p>Extents [minx], [miny], [maxx], [maxy]</p>
<p>Map size (screen) [mapsize]</p>
<p>Map width [mapwidth]</p>
<p>Map height [mapheight]</p>
<p>Map [map]</p>
<p>Layers [layers]</p>
</body>
</html>
<plaintext>
