mapserver error
Lee Keel
lee_keel at TRIMBLE.COM
Fri Jan 18 13:40:49 EST 2008
Thomas,
The main layer is a single layer. It is not a group layer and I have removed all labels. The basemap is a group layer that is coming from tilecache as a base layer. The basemap layer works 100% of the time, its the main that is not working. So even though the basemap is working all the time, could that be causing the other layer to not work?
Meanwhile, I will continue to follow all the layers from the groups and make sure they don't have the angle follow.
Thanks,
Lee
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Fri 1/18/2008 10:39 AM
To: Lee Keel
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] mapserver error
coming back again at my angle follow question...
the layers you request, ie main and/or basemap are layer groups right,
not just single layers. can you make sure that angle follow is
disabled for *all* layers in the corresponding group.
just checking 'cause there was a recently fixed problem here that
could have multiple effects when using follow labels and non ascii
characters
tb
On Jan 18, 2008 4:21 PM, Lee Keel <lee_keel at trimble.com> wrote:
> Thanks Ed. I will do that. Was just trying not to cross post and hoping that there were enough of the OL guys on this list. But I will fwd on to OL list.
> From: UMN MapServer Users List on behalf of Ed McNierney
> Sent: Fri 1/18/2008 8:58 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Lee -
> While you might get info here, you should also post this to the
> OpenLayers list to get info on "what's different in OL".
> - Ed
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Lee Keel
> Sent: Friday, January 18, 2008 9:43 AM
> Hello all.
> I have a new twist to my problem that I believe rules
> mapserver->postgres out. I added a layer last night that are the labels
> for the roads and I am getting both problems with this layer now as
> well. However, these labels are coming from TIGER shape files instead
> of postgres.
> Here is something else I have monkeyed with. If I use
> http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map&layers=ba
> semap+basemap_anno) then all of my layers seem to be working at any zoom
> level. But if I go to my openlayers application, they don't always
> work. If you get a layer not working in the OL app and check the URL,
> it doesn't seem to be incorrect. So what is the difference between OL
> requesting from mapserver based on a bbox and the HTML below requesting
> an image from mapserver?
> Sorry for my newby questions and 1,000s of emails, but just trying to
> narrow this down.
> Thanks,
> LK
> Map File Settings for WEB:
> WEB
> TEMPLATE 'gas.html'
> IMAGEPATH "d:/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> LOG "gas.log"
> METADATA
> wms_title "WMS"
> wms_onlineresource
> "http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map
> <http://webserver/cgi-bin/mapserv.exe?map=/mapserver/pc/gas.map> &"
> "wms_srs" "EPSG:2238"
> "WMS_FEATURE_INFO_MIME_TYPE" "text/html"
> end
> END
> Gas.HTML File that is being used:
> <html xmlns="http://www.w3.org/1999/xhtml <http://www.w3.org/1999/xhtml>
> <head>
> <meta name="generator" content="HTML Tidy for Windows (vers 1st June
> 2004), see www.w3.org <http://www.w3.org <http://www.w3.org%20%3chttp//www.w3.org/> > > " />
> <title>MapServer Workshop (panamacity)</title>
> <meta http-equiv="Content-Type" content="text/html; charset=us-ascii"
> </head>
> <body bgcolor="#FFFFFF" text="#000000">
> <h3></h3>
> <!-- START OF MAPSERVER FORM -->
> <form name="mapserv" method="get"
> action="http://webserver/cgi-bin/mapserv.exe
> <http://webserver/cgi-bin/mapserv.exe> " id="mapserv">
> <!-- HIDDEN MAPSERVER CGI VARIABLES -->
> <input type="hidden" name="map" value="[map]" />
> <input type="hidden" name="imgext" value="[mapext]" />
> <input type="hidden" name="imgxy" value="199.5 149.5" />
> <table>
> <tr>
> <td>
> <!-- SPECIFY MAP MODE -->
> <div align="center">Map Mode:
> <select name="mode">
> <option value="browse">Browse</option>
> <option value="map">Map</option>
> </select>
> Layers: <input type="TEXT" name="layers" value="[layers]" />
> </div>
> </td>
> <td>
> <!-- FORM SUBMIT BUTTON -->
> <input type="submit" name="submit" value="Refresh" />
> </div>
> </td>
> <td>
> <!-- ZOOM/PAN CONTROLS -->
> <div align="center">Map Control:
> <select name="zoom">
> <option value="4" [zoom_4_select]>Zoom In 4x</option>
> <option value="3" [zoom_3_select]>Zoom In 3x</option>
> <option value="2" [zoom_2_select]>Zoom In 2x</option>
> <option value="1" [zoom_1_select]>Recenter</option>
> <option value="-2" [zoom_-2_select]>Zoom Out 2x</option>
> <option value="-3" [zoom_-3_select]>Zoom Out 3x</option>
> <option value="-4" [zoom_-4_select]>Zoom Out 4x</option>
> </select>
> </div>
> </td>
> <td rowspan="2" valign="top">
> <!-- <p>Reference:<br />
> <img name="ref" src="[ref]" id="ref" />
> </p> -->
> <p>Legend:<br />
> <img name="legend" src="[legend]" id="legend" />
> </p>
> </td>
> </tr>
> <tr>
> <!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
> <td colspan="3" align="center" valign="top">
> <input type="image" name="img" src="[img]" width="800"
> height="600" border="0" />
> <table border="0" width="600" align="center">
> <!-- DISPLAY THE SCALE BAR -->
> <tr>
> <td align="right"><!-- <img src="[scalebar]" /> --></td>
> </tr>
> </table>
> </td>
> </tr>
> </table>
> <input name="mapxy" type="text" value="[mapx] [mapy]" />
> </form>
> <p>Map scale 1:[scale]</p>
> <p>Pixel size [cellsize]</p>
> <p>Extents [minx], [miny], [maxx], [maxy]</p>
> <p>Map size (screen) [mapsize]</p>
> <p>Map width [mapwidth]</p>
> <p>Map height [mapheight]</p>
> <p>Map [map]</p>
> <p>Layers [layers]</p>
> </body>
> </html>
> <plaintext>
