featureitemquery help
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Jan 22 10:34:49 EST 2008
Someone else had almost the same question recently. Check out this thread: http://lists.umn.edu/cgi-bin/wa?A2=ind0801&L=mapserver-users&T=0&F=&S=&P=12017
You have likely put the image tag in your main query template, if you move it to the header template or the footer template, it will only be displayed once for each query.
If you are not seeing data values returned in your query, you may not have placed the column names in your query template, or they may not be specified properly. The column names may be case sensitive.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Paul Alarcon
Sent: Monday, January 21, 2008 10:46 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] featureitemquery help
Hello
I am new here and i am having some problems with this kind of query , when,
I`m using html for the page and postgis to create the layers but when i
made the query a lot of map display each time and dont show me the
information please could you help me,
Here is the html and the map files
HTML
<html>
<head>
<title>Busqueda por CANTON</title>
<body>
<form name="consulta" method=GET action="/cgi-bin/mapserv">
<input name="program" value="/cgi-bin/mapserv" type="hidden">
<input name="map" value="/home/test/testexpression.map" type="hidden">
<!-- parametros pasados en hidden -->
<input name="mode" value="itemfeaturequery" type="hidden">
<input name="slayer" value="cantones" type="hidden">
<input name="qitem" value="non_canton" type="hidden">
<input type="hidden" name="mapshape" value="">
<input type="hidden" name="imgshape" value="">
<input type="hidden" name="imgbox" value="">
<input type="hidden" name="shapeindex" value="">
<!-- parametros de busqueda -->
Seleccione un Cantón: <br>
<select name="qstring" >
<option value="non_canton like 'LAGO AGRIO'">LAGO AGRIO</option> <option value="non_canton like 'SUCUMBIOS'">SUCUMBIOS</option> <option value="non_canton like 'GONZALO PIZARRO'">GONZALO PIZARRO</option> <option value="non_canton like 'CASCALES'">CASCALES</option> <option value="non_canton like 'SHUSHUFINDI'">SHUSHUFINDI</option>
<option value="non_canton like 'CUYABENO'">CUYABENO</option> <option value="non_canton like 'PUTUMAYO'">PUTUMAYO</option></select>
<p>
<input value="BUSCAR" type="submit">
</form>
</body>
</html>
MAP FILE
MAP
NAME test #MapFile testing possible bug on itemquery
STATUS ON
SIZE 800 600
EXTENT 836705.704288 9999113.003817 1143436.012879 10051849.051893
STATUS ON
#SHAPEPATH "/home/mapdata/Pichincha/pruebas/POLITICO 2002/"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
FONTSET "/srv/www/htdocs/ka-map/fontset.txt"
WEB
IMAGEPATH "/srv/www/htdocs/temp/"
IMAGEURL "/temp/"
TEMPLATE "querytemplate.html"
END # End of Web Interface
# Symbol para lineas gruesas
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol para puntos
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
#Symbol cuadrado base
SYMBOL
NAME "Cuadro"
TYPE VECTOR
POINTS
0 0
0 1
1 1
1 0
0 0
END
FILLED TRUE
END
#SYMBOL circulo
SYMBOL
NAME "punkt"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
querymap
status ON
SIZE 400 300
style SELECTED
END
LAYER
NAME cantones
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "host=localhost port=5432 dbname=demo_postgis user=postgres
password="
DATA "the_geom from cantones"
LABELCACHE on
TOLERANCE 0
METADATA
qstring_validation_pattern '.'
END
LABELITEM "non_canton"
CLASS
NAME "None"
OUTLINECOLOR 0 0 0
COLOR 187 212 201
END
END #end layer ############################################################3
LAYER
NAME parroquias
STATUS DEFAULT
TYPE line
password="
DATA "the_geom from parroquias"
STATUS default
#METADATA
# qstring_validation_pattern '.'
#END
LABELITEM "parroquia"
#DATA 'parroquial'
CLASS
NAME "None"
#OUTLINECOLOR 100 0 0
COLOR 0 5 5
END
END #end layer
LAYER
NAME PROVINCIAS
STATUS DEFAULT
TYPE line
#METADATA
#END
#LABELITEM "PARROQUIA"
#DATA 'provincial'
password="
DATA "the_geom from provincial"
CLASS
NAME "None"
COLOR 0 0 5
STYLE
SYMBOL "BigLine"
SIZE 4
#COLOR 50 212 51
OUTLINECOLOR 12 0 0
END
END
END #end layer
LAYER
NAME "Escuelas"
user=postgres password="
DATA "the_geom from sucumbios"
STATUS default
TYPE point
LABELITEM "plantel"
LABELCACHE on
HEADER "/srv/www/htdocs/head_plan.html"
FOOTER "/srv/www/htdocs/foot_plan.html"
CLASSITEM "nivel"
METADATA
"queryable" "true"
"searchfield" "canton"
# "fields" "canton:CANTON,parroqui_1:PARROQUIA,nombre_esc:NOMBRE"
END
GROUP "PLANTELES"
CLASS
NAME "PREPRIMARIO"
EXPRESSION "Preprimario"
STYLE
SYMBOL "cuadro"
SIZE 10
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
STYLE
SYMBOL "punkt"
SIZE 8
COLOR 204 204 255
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
#BACKGROUNDCOLOR 255 255 255
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END #label
END #clase
CLASS
NAME "PRIMARIO"
EXPRESSION "Primario"
STYLE
SYMBOL "cuadro"
SIZE 10
COLOR 0 255 0
OUTLINECOLOR 0 0 0
END
STYLE
SYMBOL "punkt"
SIZE 8
COLOR 204 204 255
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END #label
END # Clase
CLASS
NAME "MEDIO"
EXPRESSION /^Medio/
STYLE
SYMBOL "cuadro"
SIZE 10
COLOR 0 0 255
OUTLINECOLOR 0 0 0
END
STYLE
SYMBOL "punkt"
SIZE 8
COLOR 204 204 255
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END
END
CLASS
NAME "S/Dato"
EXPRESSION " "
STYLE
SYMBOL "Circle"
SIZE 10
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 50
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END
END
END #LAYER ###########################################################################
END #end mapfile
_________________________________________________________________
MSN Amor: busca tu ½ naranja http://latam.msn.com/amor/
