one way roads, drawing spaced arrows
    rich.fromm
    nospam420 at YAHOO.COM
    Tue Jan 22 11:30:19 PST 2008
tbonfort wrote:
> you're right the documentation is a bit off.
> for line symbology, the rule is
> GAP>0: symbols face north (or rotated wrt north by their ANGLE parameter)
> GAP =0: symbol is used to 'texture' the line (useful with pixmap or
> vector symbols)
> GAP<0: symbol is oriented according to the line direction (this can
> also be modified with the ANGLE parameter, eg to rectify an arrow
> pointing 90 degrees off)
Okay, that indeed worked for a truetype symbol.  Thanks.
But do you know about a vector symbol?  That is slightly my preference here,
but I can't get any spacing to work.  If I try PATTERN (formerly STYLE, I
believe), it has no effect.  The symbol is repeated as before.  If I instead
try GAP, anything (either positive or negative) other than 0 (the presumed
default) causes the symbol to not even be drawn at all.
- Rich
View this message in context: http://www.nabble.com/one-way-roads%2C-drawing-spaced-arrows-tp15006747p15026218.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
