Map file with 35,000+ Lines... management issue
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Jan 23 14:28:35 EST 2008
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Espen Isaksen
> Sent: 23 January, 2008 2:26 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+
> Regarding this, is it possible to "include" a map file inside
> another map file?
One can do just this with the INCLUDE directive. See
http://mapserver.gis.umn.edu/docs/reference/mapfile/Include
..Tom
> Espen
> On 23/01/2008, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> > Everything is a performance issue, the question is, 'Is the
> > performance acceptable to you?'...
> > You have built a pretty massive map file. I would look at
> stripping
> > it down to only what is needed for a particular application.
> > For questions about how to improve performance, you may
> want to look at:
> > http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
> > David.
> > On Behalf Of riteshambastha
> > Sent: Wednesday, January 23, 2008 12:59 PM
> > Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
> > management issue
> > Thanks Rich,
> > Yeah, even I am trying to solve this issue by separating
> the huge map
> > file with smaller chunks of many map files. Am bit confused
> if it will
> > lead to performance issues.
> > Warm Regards,
> > Ritz
> > rich.fromm wrote:
> > > riteshambastha wrote:
> > >> I have developed a map file with more than 35,000 Lines.
> > >> Please throw some lights over writing map files by
> following best
> > >> practices.
> > > Have you considered more than one map file, depending on the
> > > circumstances, each one a bit smaller, rather than one
> huge map file?
> > > It's hard to say how appropriate that may or may not be without
> > > knowing more about your circumstances, but that's what I have.
> > > - Rich
> > View this message in context:
> http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-is
> > su
> > e-tp15048892p15048905.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
