[UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
management issue
Léveillé, James
James.Leveille at MTQ.GOUV.QC.CA
Wed Jan 23 14:28:08 EST 2008
As simple as
#INCLUDE
INCLUDE "other_map_file.map"
______________________________________________________
JAMES LÉVEILLÉ
Service des systèmes de Mission
Direction des technologies de l'information
Ministère des Transports du Québec
5833, boul. Pierre-Bertrand, 2ième étage
Québec (Québec) G2K 1K7
Téléphone: (418) 380-2005 poste 227
Télécopieur: (418) 644-6653
james.leveille at mtq.gouv.qc.ca
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Espen Isaksen
Envoyé : 23 janvier 2008 14:26
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines... management
issue
Regarding this, is it possible to "include" a map file inside another map
file?
Espen
On 23/01/2008, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> Everything is a performance issue, the question is, 'Is the
> performance acceptable to you?'...
> You have built a pretty massive map file. I would look at stripping
> it down to only what is needed for a particular application.
> For questions about how to improve performance, you may want to look
> at: http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On Behalf Of riteshambastha
> Sent: Wednesday, January 23, 2008 12:59 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
> management issue
> Thanks Rich,
> Yeah, even I am trying to solve this issue by separating the huge map
> file with smaller chunks of many map files. Am bit confused if it will
> lead to performance issues.
> Warm Regards,
> Ritz
> rich.fromm wrote:
> > riteshambastha wrote:
> >> I have developed a map file with more than 35,000 Lines.
> >> Please throw some lights over writing map files by following best
> >> practices.
> > Have you considered more than one map file, depending on the
> > circumstances, each one a bit smaller, rather than one huge map
> > file?
> > It's hard to say how appropriate that may or may not be without
> > knowing more about your circumstances, but that's what I have.
> > - Rich
> http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-is
> su
> e-tp15048892p15048905.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
