Map file with 35,000+ Lines... management issue
riteshambastha
ritesh.linux at GMAIL.COM
Wed Jan 23 16:29:11 EST 2008
Dear Espen,
you can use 'include' for including multiple map files.
Make one master map file, write extents etc there.. eg:
MAP
NAME 'include'
EXTENT 0 0 500 500
SIZE 250 250
INCLUDE "c:/ms4w/apps/partners/trialPost.map"
INCLUDE "c:/ms4w/apps/partners/bangPost.map"
END
Then, in the included map files, just add the LAYER parts.
Thats all !
Regard,
Ritz
Espen Isaksen wrote:
> Thanks! Don't know how I missed that one...
> Espen
> On 23/01/2008, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
>> > -----Original Message-----
>> > From: UMN MapServer Users List
>> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Espen Isaksen
>> > Sent: 23 January, 2008 2:26 PM
>> > To: MAPSERVER-USERS at LISTS.UMN.EDU
>> > Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+
>> > Regarding this, is it possible to "include" a map file inside
>> > another map file?
>> One can do just this with the INCLUDE directive. See
>> http://mapserver.gis.umn.edu/docs/reference/mapfile/Include
>> ..Tom
>> > Espen
>> > On 23/01/2008, Fawcett, David <David.Fawcett at state.mn.us> wrote:
>> > > Everything is a performance issue, the question is, 'Is the
>> > > performance acceptable to you?'...
>> > > You have built a pretty massive map file. I would look at
>> > stripping
>> > > it down to only what is needed for a particular application.
>> > > For questions about how to improve performance, you may
>> > want to look at:
>> > > http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
>> > > David.
>> > > On Behalf Of riteshambastha
>> > > Sent: Wednesday, January 23, 2008 12:59 PM
>> > > Subject: Re: [UMN_MAPSERVER-USERS] Map file with 35,000+ Lines...
>> > > management issue
>> > > Thanks Rich,
>> > > Yeah, even I am trying to solve this issue by separating
>> > the huge map
>> > > file with smaller chunks of many map files. Am bit confused
>> > if it will
>> > > lead to performance issues.
>> > > Warm Regards,
>> > > Ritz
>> > > rich.fromm wrote:
>> > > > riteshambastha wrote:
>> > > >> I have developed a map file with more than 35,000 Lines.
>> > > >> Please throw some lights over writing map files by
>> > following best
>> > > >> practices.
>> > > > Have you considered more than one map file, depending on the
>> > > > circumstances, each one a bit smaller, rather than one
>> > huge map file?
>> > > > It's hard to say how appropriate that may or may not be without
>> > > > knowing more about your circumstances, but that's what I have.
>> > > > - Rich
>> > > View this message in context:
>> > http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-is
>> > > su
>> > > e-tp15048892p15048905.html
>> > > Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-issue-tp15048892p15053008.html
