Use of multiple sid files
Matthew Perry
perrygeo at GMAIL.COM
Fri Jan 25 02:30:25 EST 2008
On Jan 23, 2008 10:08 AM, Lee Keel <lee_keel at trimble.com> wrote:
> I have figured out that I cannot use tile4ms directly with the sid files, but can I use it to create an index of an index file? In other words: can I create an index shape file for a group of the sid files then use tile4ms to create a "master" index shape file with group of the sid shape files in it?
If you have gdal built with mrsid support, you can use the gdaltindex
utility directly on the .sid files instead of using tile4ms.
Matthew T. Perry
http://www.perrygeo.net
