mapserver doesnt't see libgdal
Guillaume Sueur
guillaume.sueur at NEOGEO-ONLINE.NET
Mon Jan 28 09:36:20 EST 2008
just a clue :
add your ~/homemade/lib/ to /etc/ld.so.conf and run ldconfig as root
Guillaume
Peter Loewe a écrit :
> Hi,
> I am trying to compile MS from the 5.0.1 source on a remote (webhosting) system (i have no root priviliges there).
> For some unknown reason, mapserver refuses to acknowledge the location of libgdal [GDAL itself was built from the sources (1.5.0) and shows no problems]:
> ---MS-Configure:
> LDFLAGS='-L/home/pacs/aho02/users/loewe01/homemade/lib -L/lib -L/usr/lib -L/usr/local/lib -L/usr/X11R6/lib -Wl,-rpath=/home/pacs/xxx/homemade/lib' \
> ./configure \
> --prefix=/home/pacs/xxx/homemade/lib \
> --enable-runpath \
> --with-gd=/home/pacs/xxx/homebuilt/gd-2.0.33 \
> --with-proj \
> --with-gdal=/home/pacs/xxx/homemade/bin/gdal-config \
> --without-ogr \
> --without-wcs \
> --with-wmsclient \
> --with-wms \
> --without-wfs \
> --without-wfsclient \
> --with-xml2-config=/usr/bin/xml2-config \
> --without-sos \
> --with-pdf=/home/pacs/xxx/homebuilt/PDFlib-6.0.3p5-Linux/bind/c \
> --with-php=/usr/local/share/php/5.1.1
> MS compiles nicely.
> Unfortunately, this is what ldd mapserv has to tell:
> ldd mapserv
> linux-gate.so.1 => (0xb7f68000)
> libgd.so.2 => /home/pacs/xxx/homebuilt/gd-2.0.33/.libs/libgd.so.2 (0xb7f17000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb7eeb000)
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7e81000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb7e5e000)
> libz.so.1 => /usr/lib/libz.so.1 (0xb7e4a000)
> libXpm.so.4 => /usr/lib/libXpm.so.4 (0xb7e3a000)
> libX11.so.6 => /usr/lib/libX11.so.6 (0xb7d4e000)
> libproj.so.0 => /usr/lib/libproj.so.0 (0xb7d18000)
> libgdal.so.1 => not found
> Yet, libgdal.so.1 _does_ exist:
> ls -l ~/homemade/lib/
> -rw-r--r-- 1 libgdal.a
> -rwxr-xr-x 1 libgdal.la
> lrwxrwxrwx 1 libgdal.so -> libgdal.so.1.12.0
> lrwxrwxrwx 1 libgdal.so.1 -> libgdal.so.1.12.0
> -rwxr-xr-x 1 libgdal.so.1.12.0
> -rw-r--r-- 1 libpdf.a
> Has anybody encountered this before ?
> ANY suggestion would be much appreciated!
> Peter
