mapserver doesnt't see libgdal
"Peter Löwe"
peter.loewe at GMX.DE
Mon Jan 28 09:51:16 EST 2008
Frank,
thanks for the hint, it has been already tried and did not help:
If a wrapper is used, mapserv falls into some sort of an ugly infinite loop.
BTW: gdal-config is obviously aware of the correct locations of the libs:
~/homemade/bin$ ./gdal-config --libs
-L/home/pacs/xxx/homemade/lib -lgdal
Still puzzled,
Peter
-------- Original-Nachricht --------
> Datum: Mon, 28 Jan 2008 09:41:56 -0500
> Von: Frank Warmerdam <warmerdam at pobox.com>
> An: peter.loewe at GMX.DE
> CC: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] mapserver doesnt\'t see libgdal
> Peter Loewe wrote:
> > Hi,
> > I am trying to compile MS from the 5.0.1 source on a remote (webhosting)
> system (i have no root priviliges there).
> > For some unknown reason, mapserver refuses to acknowledge the location
> of libgdal [GDAL itself was built from the sources (1.5.0) and shows no
> problems]:
> > Unfortunately, this is what ldd mapserv has to tell:
> > ldd mapserv
> > linux-gate.so.1 => (0xb7f68000)
> > libgd.so.2 =>
> /home/pacs/xxx/homebuilt/gd-2.0.33/.libs/libgd.so.2 (0xb7f17000)
> > libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb7eeb000)
> > libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7e81000)
> > libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb7e5e000)
> > libz.so.1 => /usr/lib/libz.so.1 (0xb7e4a000)
> > libXpm.so.4 => /usr/lib/libXpm.so.4 (0xb7e3a000)
> > libX11.so.6 => /usr/lib/libX11.so.6 (0xb7d4e000)
> > libproj.so.0 => /usr/lib/libproj.so.0 (0xb7d18000)
> > libgdal.so.1 => not found
> > Yet, libgdal.so.1 _does_ exist:
> > ls -l ~/homemade/lib/
> > -rw-r--r-- 1 libgdal.a
> > -rwxr-xr-x 1 libgdal.la
> > lrwxrwxrwx 1 libgdal.so -> libgdal.so.1.12.0
> > lrwxrwxrwx 1 libgdal.so.1 -> libgdal.so.1.12.0
> > -rwxr-xr-x 1 libgdal.so.1.12.0
> > -rw-r--r-- 1 libpdf.a
> > Has anybody encountered this before ?
> > ANY suggestion would be much appreciated!
> Peter,
> Setup the LD_LIBRARY_PATH environment variable to point to
> /home/pacs/xxx/homemade/lib. You can try this at the commandline
> initially but you will likely want to accomplish it with a wrapper
> script around mapserv when you are ready to deploy things as a cgi.
> (assuming you also can't modify the apache configuration).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Dr. Peter Löwe
<peter.loewe at gmx.de>
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
