Mapserver PostGIS Custom SRID Problem
Paul Moen
pmoen at OFFROADSOFTWARE.COM
Tue Jan 29 20:02:53 EST 2008
My own error was causing the problem. I was editing a mapfile that
wasn't actually being used.
On Jan 29, 2008, at 5:53 PM, Paul Moen wrote:
> This is my layer.
> LAYER
> NAME "Montana"
> PROJECTION
> "init=epsg:1038007"
> END
> CONNECTION "user=postgres dbname=1038007 host=127.0.0.1
> port=5432"
> CONNECTIONTYPE postgis
> DATA "the_geom from mt_counties using unique gid using
> SRID=1038007"
> TYPE POLYGON
> STATUS ON
> CLASS
> NAME "MT counties"
> STYLE
> COLOR 245 245 245
> OUTLINECOLOR 200 200 200
> END
> END
> END
> I am using the user postgres for the sql statement .
> This is the actual command that I used from the command line.
> psql -d 1038007 -U postgres -c "SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
> mt_counties WHERE the_geom && setSRID('BOX3D(1792876.6493994
> 343910,2160707.3506006 612229)'::BOX3D, 1038007 )"
> These are all performed on the same server that PostgreSQL is running.
> I do have the database named 1038007. Is there a problem with
> database names being all numerals within PostgreSQL? Everything
> seems to work fine except when mapserver is making the call.
> On Jan 29, 2008, at 5:33 PM, Paul Ramsey wrote:
>> There's something wrong, because the same SQL should return the
>> same result... there should not be a non-deterministic difference
>> depending on from where you enter it. Are you sure you're entering
>> it in the same database, using the same user, as mapserver is?
>> P
>> Paul Moen wrote:
>>> 1 row equal to 1038007
>>> On Jan 29, 2008, at 3:46 PM, Paul Ramsey wrote:
>>>> what does
>>>> SELECT DISTINCT SRID(the_geom) from mt_counties;
>>>> return?
>>>> what does
>>>> SELECT * FROM geometry_columns WHERE f_table_name = 'mt_counties';
>>>> return?
>>>> Paul Moen wrote:
>>>>> I get the following error when trying to draw a layer that
>>>>> exists in postgis.
>>>>> [MapServer Error]: msPOSTGISLayerWhichShapes(): Error executing
>>>>> POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor BINARY
>>>>> CURSOR FOR SELECT
>>>>> from mt_counties WHERE the_geom &&
>>>>> setSRID('BOX3D(1792876.6493994 343910,2160707.3506006
>>>>> -ERROR: Operation on two geometries with different SRIDs
>>>>> If I issue the following sql command in postgis two rows are
>>>>> returned rather than the error.
>>>>> SELECT
>>>>> The custom SRID has been added to the spatial_ref_sys table in
>>>>> postgis and the epsg file in the proj resources. These layers
>>>>> display exactly the way I want when viewing with Qgis connected
>>>>> as postGIS layers.
>>>>> Does anyone have any ideas on what I can do to further
>>>>> troubleshoot this? Is this a problem with mapserver, postgis,
>>>>> or something I am doing? Version info.
>>>>> Mac OS 10.4.11
>>>>> "POSTGIS="1.2.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22
>>>>> Oct 2006" USE_STATS"
>>>>> MapServer Version MapServer version 4.10.1 OUTPUT=GIF
>>>>> OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF
>>>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=GEOS
>>>>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>>> PHP MapScript Version ($Revision: 1.260.2.1 $ $Date:
>>>>> 2006/11/22 19:34:45 $)
>>>>> Thanks,
>>>>> Paul
>>>> Paul Ramsey
>>>> Refractions Research
>>>> http://www.refractions.net
>>>> pramsey at refractions.net
>>>> Phone: 250-383-3022
>>>> Cell: 250-885-0632
>> Paul Ramsey
>> Phone: 250-383-3022
>> Cell: 250-885-0632
