queryByShape Problem
Guillaume Sueur
guillaume.sueur at NEOGEO-ONLINE.NET
Wed Jan 30 11:45:11 EST 2008
Oups ! read the stuff too fast. The query object IS a polygon.
In fact your point does'nt seem to be INTO the polygon. Have a check
with OpenLayers vector capabilities, in which you can test WKTs :
http://www.openlayers.org/dev/examples/vector-formats.html
Guillaume Sueur a écrit :
> Hi Josh,
> See mapscript documentation about this function :
> Query layer based on a single shape, the shape has to be a polygon
> at this point.
> Sorry !
> Josh Hevenor a écrit :
>> Good morning,
>> I’m having trouble getting a response from PHP MapScript’s
>> Layer::queryByShape()
>> I’m trying to query an OGR point layer by a Polygon Shape that I got
>> from querying a different layer. queryByAttribute on the same OGR
>> Point layer is working properly.
>> My code looks like:
>> if($bannerLayer->queryByShape($tradeAreaShape)==MS_SUCCESS){
>> } else {
>> Echo “FOUND NOTHING!”;
>> The WKT of tradeAreaShape is
>> POLYGON ((-63.5931228499999290 44.6328285400000480,
>> -63.5947725799999260 44.6335656500000940, -63.5951314899999720
>> 44.6341621000000830, -63.5957245999999260 44.6340256500000690,
>> -63.5965530599999620 44.6338150900000410, -63.5968179299999290
>> 44.6337532300000820, -63.5977474799999530 44.6335363100000680,
>> -63.5982376599999380 44.6333897900000810, -63.5988134899999410
>> 44.6332354000000460, -63.5987020099999540 44.6332166200000420,
>> -63.5971723199999700 44.6327559600000540, -63.5969579099999580
>> 44.6327936700000690, -63.5964623699999270 44.6323998900000450,
>> -63.5946525499999780 44.6317434200000780, -63.5938438599999360
>> 44.6315586800000690, -63.5932997099999400 44.6312995200000840,
>> -63.5928279799999250 44.6307981100000570, -63.5924848199999250
>> 44.6305387700000440, -63.5919616199999500 44.6299659500000420,
>> -63.5916053899999270 44.6296526400000740, -63.5909086899999350
>> 44.6292868500000850, -63.5899865099999600 44.6291208900000810,
>> -63.5892757299999400 44.6286565300000580, -63.58845245
> 99999280 44.6282188300000940, -63.5874521599999410 44.6277828000000910,
> -63.5860267299999580 44.6277003300000390, -63.5850517499999340
> 44.6273278300000700, -63.5841646099999590 44.6268552600000700,
> -63.5839624399999370 44.6268111700000530, -63.5838486099999610
> 44.6267392600000790, -63.5831529099999670 44.6265364200000930,
> -63.5826986099999660 44.6264936700000590, -63.5820406399999460
> 44.6262448900000660, -63.5816217099999220 44.6259225200000740,
> -63.5814790499999280 44.6255455100000520, -63.5812254099999450
> 44.6253663000000530, -63.5807831799999690 44.6253010900000500,
> -63.5812146799999600 44.6263535200000660, -63.5815108999999550
> 44.6275863300000420, -63.5816280799999730 44.6279660300000390,
> -63.5816691499999250 44.6280994700000520, -63.5816917799999710
> 44.6291450300000750, -63.5818721599999320 44.6295401500000820,
> -63.5820067699999640 44.6298511200000690, -63.5822121299999590
> 44.6303349300000600, -63.5823497599999430 44.6306541100000800,
> -63.5833684999999490 44.630405840000
> 0940, -63.5843872299999480 44.6301575700000510, -63.5853932299999660
> 44.6299183500000820, -63.5862579099999720 44.6318944600000690,
> -63.5867230999999720 44.6330173000000630, -63.5868909099999660
> 44.6334035400000740, -63.5909856299999770 44.6318880900000750,
> -63.5927758399999450 44.6326734800000510, -63.5931228499999290
> 44.6328285400000480))
>> And a point that should be found is
>> POINT (-63.573535919189 44.637145996094)
>> Thanks once again,
>> Josh Hevenor
>> Application Developer
>> ____________________________________________
>> 5230 South Service Road
>> Burlington, Ontario
>> L7L 5K2 Canada
>> **Email: josh.hevenor at dpra.com***
>> *Internet: http://www.dpra.com*
>> **Attention:***
>> *Privileged/Confidential Information may be contained in this message.
>> Disclosure to any person other than the named recipient is
>> unauthorized. If you are not the intended recipient, please delete all
>> copies of this information and kindly notify the sender by reply
>> email. Opinions, conclusions and other information in this message
>> that do not relate to the official business of DPRA shall be
>> understood as neither given nor endorsed by it. DPRA and any of its
>> subsidiaries reserve the right to monitor all e-mail communications
>> through its networks. Thank you.
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
