Libgd.so.2 -> Library not found
Seethaler, Lyle [USA]
seethaler_lyle at BAH.COM
Wed Jan 30 11:41:45 EST 2008
As a result of restrictions on the container I am working I can not
build libraries into the /usr/lib/ directories. As a result the
libraries that I built for MapServer (gd, curl, etc) are in a different
location. I specify these locations in the configuration file and the
makefile lists these locations correctly and runs fine. However once I
test the mapserv executable it does not see these libraries. Am I
missing a parameter for setting these library locations into the cgi?
Should i be setting an environment variable with these locations? Any
help in this issue is much appreciated.
Thanks in advance!
Lyle
# mapserv
ld.so.1: mapserv: fatal: libgd.so.2: open failed: No such file or
directory
# ldd mapserv
libgd.so.2 => (file not found)
libjpeg.so.62 => /usr/lib/libjpeg.so.62
libfreetype.so.6 => /usr/sfw/lib/libfreetype.so.6
libpng.so.3 => /usr/lib/libpng.so.3
libz.so.1 => /usr/lib/libz.so.1
libXpm.so.4 => /usr/lib/libXpm.so.4
libX11.so.4 => /usr/lib/libX11.so.4
libtiff.so.3 => /usr/lib/libtiff.so.3
libproj.so.0 => (file not found)
libgdal.so.1 => (file not found)
libpq.so.5 => (file not found)
librt.so.1 => /usr/lib/librt.so.1
libdl.so.1 => /usr/lib/libdl.so.1
libcurl.so.4 => (file not found)
libssl.so.0.9.7 => /usr/sfw/lib/libssl.so.0.9.7
libcrypto.so.0.9.7 => /usr/sfw/lib/libcrypto.so.0.9.7
libldap.so.5 => /usr/lib/libldap.so.5
libsocket.so.1 => /usr/lib/libsocket.so.1
libnsl.so.1 => /usr/lib/libnsl.so.1
libclntsh.so.10.1 => (file not found)
libgeos_c.so.1 => (file not found)
libpthread.so.1 => /usr/lib/libpthread.so.1
libxml2.so.2 => /usr/lib/libxml2.so.2
libm.so.2 => /usr/lib/libm.so.2
libstdc++.so.6 => /usr/sfw/lib/libstdc++.so.6
libc.so.1 => /usr/lib/libc.so.1
libgcc_s.so.1 => /usr/sfw/lib/libgcc_s.so.1
libXext.so.0 => /usr/openwin/lib/libXext.so.0
libaio.so.1 => /lib/libaio.so.1
libmd5.so.1 => /lib/libmd5.so.1
libsasl.so.1 => /usr/lib/libsasl.so.1
libnspr4.so => /usr/lib/mps/libnspr4.so
libplc4.so => /usr/lib/mps/libplc4.so
libnss3.so => /usr/lib/mps/libnss3.so
libssl3.so => /usr/lib/mps/libssl3.so
libmp.so.2 => /lib/libmp.so.2
libscf.so.1 => /lib/libscf.so.1
libthread.so.1 => /lib/libthread.so.1
libsoftokn3.so => /usr/lib/mps/libsoftokn3.so
libplds4.so => /usr/lib/mps/libplds4.so
libdoor.so.1 => /lib/libdoor.so.1
libuutil.so.1 => /lib/libuutil.so.1
libbsm.so.1 => /lib/libbsm.so.1
libsecdb.so.1 => /lib/libsecdb.so.1
libtsol.so.2 => /lib/libtsol.so.2
libcmd.so.1 => /lib/libcmd.so.1
/platform/SUNW,Sun-Fire-480R/lib/libc_psr.so.1
/platform/SUNW,Sun-Fire-480R/lib/libmd5_psr.so.1
/usr/lib/mps/cpu/sparcv8plus/libnspr_flt4.so
Example taken from Makefile:
GDFONT_OBJ=gd-1.2/gdfontt.o gd-1.2/gdfonts.o gd-1.2/gdfontmb.o
gd-1.2/gdfontl.o gd-1.2/gdfontg.o
GD_INC= -I/var/usrtmp/local/include
GD_LIB= -L/var/usrtmp/local/lib -lgd -L/usr/lib -ljpeg -lfreetype -lpng
-lz -lXpm -lX11
GD= -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
-DGD_HAS_GETBITMAPFONTS
GD_STATIC =
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080130/c95b913c/attachment.html
