Hallo list, how can I set the extent of a reference map object with PHP/Mapscript. If is I use the “set()” function I get the error: “PHP Fatal error: Property 'extent' is an object and cannot be set using set(). Use the extent object's methods instead.” But I can’t find an “extent()” or “setextent()” function. Thanks for any help, Roman
